Problem in Sparse linear solvers
Posted 2012/07/22 10:09 GMT-4 Structural Mechanics Version 4.1 2 Replies
Dear Mr.Ivar and COMSOL users
I am modeling thermal stresses during solidification.
first i did heat transfer with solidification(by increasing cp of the steel ). then I used solid mechanics.
all works fine ..
when i use Yong modulus as constant 70e9 model works fine..
but when i use temperature dependant Young modulus the error comes..
when Temp=20C ,E=200GPa
Temp=1440C ,E=0 GPa
in the liquid state to eliminate stresses Yongmodulus value is used as 0 GPa
similarly posiions ratio is 0.49 in liquid and 0.3 for solid steel..
this way of modeling is followed by many users but i read that , it cuases ILL CONDITIONING OF GLOBAL MATRICES which might be a problem for sparse liner solvers.
so i tried different solvers but i am unsuccessful ..
when E=constant ..model works
when E= temperature dependent value model gives the error
'''Inverted mesh element near coordinates (0.564742, 0.443981)'''
i tried to use the damping factor as
initial damping factor 0.01
recovery damping factor 0.01
i tried many ways .but got the same error
can you please put me out of this problem
i am attching my model here
all works fine ..
Temp=1440C ,E=0 GPa
2 Replies Last Post 2012/07/24 4:51 GMT-4
