Question about using multiple processors in Gui mode for "form union" operation
I am currently working in the RF module on a cluster. Right now, I'm working with a very large geometry (large in that it contains many domains). It is so large that it takes a very long time for the "form union" operation to be performed. I've tried simplifying the final union operation by first doing several ordinary union operations with "keep interior boundaries" checked, the idea being to split up the process into several steps. That helped to an extent. Each one of these operations would run in a day or so, but now, it seems to have stopped working.
My question is, is there any way to use multiple processors for things like "form union" or other geometrical operations, or can that only be done for meshing and solving? I've tried it in batch mode and it only seemed to use one processor, even though I assigned it many. I'm currently using one node of the cluster with 48 processors. In earlier models, multiple processors were being used, but that was apparently for solving and meshing.
Now, I'm using the Gui mode in a torque shell on the cluster, but it's the same story. I assigned all of the 48 processors to the shell and then opened Comsol in it with the switches " -nn 1 -np 48". When I look at the usage stats, its using one processor to 100% capacity and not using the others at all. Its also using only about 11 gigs of RAM while 256 gigs are available.
Is there anything I can do to take advantage of the resources, or is that not possible for geometrical or other pre-processing operations?
Thank you in advance for any input,
A. J. Thomas
1 Reply Last Post 2013/01/04 0:54 GMT-5
Posted: 1 decade ago 2013/01/04 0:54 GMT-5
from my knowledge COMSOL uses multiple processors when available, so corollary, if only 1 is running for the geometry processing then its programmed that way. Not all algorithm might be parallelised either. But I know from the COMSOL conference presentations that they are working on the aspect to parallelised more of their code.
When I work with huge models (>800 domains) I tend to turn off the auto-update of the plots, and off the model tree auto-update, which means I must regularly perform a manual refresh, that can indeed take 5-10 minutes
Hi from my knowledge COMSOL uses multiple processors when available, so corollary, if only 1 is running for the geometry processing then its programmed that way. Not all algorithm might be parallelised either. But I know from the COMSOL conference presentations that they are working on the aspect to parallelised more of their code. When I work with huge models (>800 domains) I tend to turn off the auto-update of the plots, and off the model tree auto-update, which means I must regularly perform a manual refresh, that can indeed take 5-10 minutes -- Good luck Ivar
