Problem with meshing
Sir,
While meshing my model, I am getting an error message as follows "Out of memory for mesh processing". What does that error mean and what are the correction requirements??
5 Replies Last Post 2013/01/29 9:22 GMT-5
Posted: 1 decade ago 2013/01/29 1:45 GMT-5
basically either get more RAM, or reduce the mesh density: use symmetry (model 1/2 or 1/4 ... if possible), use 2D instead of 3D. Even if simplifications by symmetry is not always possible, often one can simplify the geometry, but this require some "engineering" insight in the solution to decide what is or not relevant.
with my 48GB of RAM I can solve problems of 2-4 MDoF but there are many DoF per element, all depends on the physics and discretisation being used
Hi basically either get more RAM, or reduce the mesh density: use symmetry (model 1/2 or 1/4 ... if possible), use 2D instead of 3D. Even if simplifications by symmetry is not always possible, often one can simplify the geometry, but this require some "engineering" insight in the solution to decide what is or not relevant. with my 48GB of RAM I can solve problems of 2-4 MDoF but there are many DoF per element, all depends on the physics and discretisation being used -- Good luck Ivar
Posted: 1 decade ago 2013/01/29 3:23 GMT-5
Thank You Ivar...
I am currently working with 2GB RAM. I suppose that I can try with 4GB RAM!
[QUOTE] Hi basically either get more RAM, or reduce the mesh density: use symmetry (model 1/2 or 1/4 ... if possible), use 2D instead of 3D. Even if simplifications by symmetry is not always possible, often one can simplify the geometry, but this require some "engineering" insight in the solution to decide what is or not relevant. with my 48GB of RAM I can solve problems of 2-4 MDoF but there are many DoF per element, all depends on the physics and discretisation being used -- Good luck Ivar [/QUOTE] Thank You Ivar... I am currently working with 2GB RAM. I suppose that I can try with 4GB RAM!
Posted: 1 decade ago 2013/01/29 7:17 GMT-5
If you are using a 32 bit Windows system a single process cannot use more than 2 GB RAM. You can set the /3GB switch in win.ini I think. But 3GB is then the limit. I tried that once and it made my PC instable.
If you want to use more RAM you must switch to a 64 bit system.
Cheers
Edgar
If you are using a 32 bit Windows system a single process cannot use more than 2 GB RAM. You can set the /3GB switch in win.ini I think. But 3GB is then the limit. I tried that once and it made my PC instable. If you want to use more RAM you must switch to a 64 bit system. Cheers Edgar
Posted: 1 decade ago 2013/01/29 7:29 GMT-5
Cheers
Edgar
Thanks Edgar...
Is it possible to open a file (made in COMSOL 4.3a installation compatible with 32 bit) on 62 bit installation??
[QUOTE] If you are using a 32 bit Windows system a single process cannot use more than 2 GB RAM. You can set the /3GB switch in win.ini I think. But 3GB is then the limit. I tried that once and it made my PC instable. If you want to use more RAM you must switch to a 64 bit system. Cheers Edgar [/QUOTE] Thanks Edgar... Is it possible to open a file (made in COMSOL 4.3a installation compatible with 32 bit) on 62 bit installation??
Posted: 1 decade ago 2013/01/29 9:22 GMT-5
Yes, that is no problem.
