2013/02/11 14:17 GMT-5
As far as I remember, this example considers particular set of angles of incidence and polarization, at which having periodic BC in y-direction is not required. For more general case, you will need to have periodic BC in both x and y directions. They should be defined as two different sets of BC, one for each of the directions. Then if you define your k-vectors properly, everything should work just fine.
Also make sure your mesh is identical on symmetric BC.
2013/02/11 14:51 GMT-5
Thank you so much for your reply. But I'm still confused about two possible situations when I set periodic BC in both x and y directions.
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
O
O
O
OOOOOOOOOO
O
O
O
I hope you can understand what I mean for the above pictures. Could you please help me to explain that?
Thank you.
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
O
O
O
OOOOOOOOOO
O
O
O
Thank you.
2013/02/11 16:41 GMT-5
There are some mistakes for the display of the second picture. The "O" in the first three lines and last three lines should be exactly above and under the "O". That's what I really mean.
2013/02/12 12:48 GMT-5
Sorry, I don't get what those O-s mean.
2013/02/12 13:31 GMT-5
Sorry to confuse you. I mean "O" is the original single cell.
When I set the x direction periodic BC, it will become like this
OOOOOOOOOOO
When I set the y direction periodic BC, it will become like this
O
O
O
O
O
O
O
O
O
But when I set both x and y direction periodic BC, what will it be? Probably it can be periodic on the x-y plane.
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
However, there exists another probability that it may become a "cross" periodic model just like this
O
O
O
O
OOOOOOO
O
O
O
O
So I'm confused about these two probabilities and can't decide which it should be.
Thank you.
OOOOOOOOOOO
O
O
O
O
O
O
O
O
O
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
OOOOOOOOOO
O
O
O
O
OOOOOOO
O
O
O
O
Thank you.
2013/02/12 17:34 GMT-5
It's the first one with square of O's
2013/02/12 23:26 GMT-5
Thank you so much.
Thank you so much.
9 years ago
2015/04/10 8:29 GMT-4
Hi Nan Zhang
I would like to study Periodic condition in Comsol too. However, I can not locate where are the tutorial files of field in Comsol's library. Can you help me ? (Or models in
www.comsol.com/models)
Thank you very much
Best regards
Duc
Hi Nan Zhang
I would like to study Periodic condition in Comsol too. However, I can not locate where are the tutorial files of field in Comsol's library. Can you help me ? (Or models in http://www.comsol.com/models)
Thank you very much
Best regards
Duc
