2009/07/31 19:05 GMT-4
If you where somewhat more explicit about the physics you use and the model you would probably get more replies.
The ractf() function came on one of the last versions of COMSOL and is so far I have understood a simplified way to use the "weak form " integration over a boundary, which is more precise than a brute sum over edge elements.
I use it regularly for structural analysis it save me time from previous more tedious formula expressions and it works fine.
Now you have to apply the correct flux to it, I cannot tell if your "c" is the one, I propose that you look up "weak form" in the doc, then "current density integration" and search the discussion forum, there are already a few discussions around current from surface flux integration
