Magnetic-Fluid Interaction
Posted 2010/03/24 5:31 GMT-4 2 Replies
Hi everybody,
in order to simulate the behavior of a magnetorheological fluid i have created a steady flow in a 2D-tube that runs in vertical direction. At the middle of the tube i have permanent magnets on both sides of the tube. So far so easy, i had no problems generating the magnetic field but now i would like to connect the dynamic viscosity with the strength of the magnetic field. Actually, i don´t know which kind of model i´m supposed to use for this problem. Because in the Fluiddynamics i can only choose the navier-stoke-equation which is based on a newton fluid but mine should more or less behave like a Herschl-Bulkley or Casson-Fluid. In the navier-stoke model the viscosity is the same in the whole tube and in mine it should be different in every single point according to the magnetic field.
Can anybody tell me how to do this in comsol or do i need an additional modul to create such a model?
Any ideas, comments, corrections are very appreciated.
2 Replies Last Post 2010/04/20 9:53 GMT-4
