openGL error (sigserv) (solution)
Just to inform the community,
we have faced to the following error with comsol3.5a on OpenSuse 11.2 64bit server :
WARNING: Exception on Toolkit thread
java.lang.NullPointerException
at sun.awt.X11.XWindow.handleXCrossingEvent(Unknown Source)
at sun.awt.X11.XBaseWindow.dispatchEvent(Unknown Source)
at sun.awt.X11.XBaseWindow.dispatchToWindow(Unknown Source)
at sun.awt.X11.XToolkit.dispatchEvent(Unknown Source)
at sun.awt.X11.XToolkit.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
# An unexpected error has been detected by Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007fcf322dd2cc, pid=28181, tid=140527857596688
# Java VM: Java HotSpot(TM) 64-Bit Server VM (10.0-b22 mixed mode linux-amd64)
# Problematic frame:
# [thread 140528109414672 also had an error]
C [libGL.so.1+0x3e2cc] __glXSetArrayEnable+0xc
The crash appeared randomly, but quite often.
Solution:
use Mesa distributed with Comsol library instead of the system one.
Just specify
USEMESA=1
in comsol starting script
Cyril F.
15 Replies Last Post 2012/02/06 16:10 GMT-5
Posted: 1 decade ago 2010/04/28 16:12 GMT-4
I have a similar problem for several months, it systematic on heavy models
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00000035b5e97210, pid=27367, tid=1105549632
# JRE version: 6.0_18-b07
# Java VM: Java HotSpot(TM) 64-Bit Server VM (16.0-b13 mixed mode linux-amd64 )
# C [libGL.so.1+0x97210]
# If you would like to submit a bug report, please visit:
# java.sun.com/webapps/bugreport/crash.jsp
its on a CENTOS V OS, Intel based WS.
I will try the -mesa option and test it out
Thanks for the tip
Hi I have a similar problem for several months, it systematic on heavy models # # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0x00000035b5e97210, pid=27367, tid=1105549632 # # JRE version: 6.0_18-b07 # Java VM: Java HotSpot(TM) 64-Bit Server VM (16.0-b13 mixed mode linux-amd64 ) # Problematic frame: # C [libGL.so.1+0x97210] # # If you would like to submit a bug report, please visit: # http://java.sun.com/webapps/bugreport/crash.jsp # its on a CENTOS V OS, Intel based WS. I will try the -mesa option and test it out Thanks for the tip Ivar
Posted: 1 decade ago 2010/04/29 4:12 GMT-4
Now I get systematically this error (perhaps before too but it was then hidden in the flow of error info)
Warning: Found two components with the same name (Tree.cellRenderer)
COMSOL seems to behave still OK
anybody any ideas ?
Hi Now I get systematically this error (perhaps before too but it was then hidden in the flow of error info) Warning: Found two components with the same name (Tree.cellRenderer) COMSOL seems to behave still OK anybody any ideas ? Ivar
Posted: 1 decade ago 2010/04/29 4:21 GMT-4
This is the error I get on opensuse 64-bit whenever I try to open graphics (postprocess) or switch to mesh display. Any known cure for this?
*** ERROR: Canvas3D constructed with a null GraphicsConfiguration
*** This will cause a NullPointerException in a subsequent release
Exception:
(rethrown as com.femlab.util.FlFatalException)
Fatal error.
- Type: NullPointerException
Stack trace:
at com.femlab.gui.GuiMode.a(Unknown Source)
at com.femlab.gui.PostMode.a(Unknown Source)
at com.femlab.gui.GuiMode.j(Unknown Source)
at com.femlab.gui.at.a(Unknown Source)
at com.femlab.gui.bo.C(Unknown Source)
at com.femlab.gui.an.a(Unknown Source)
at com.femlab.gui.bp.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at com.femlab.gui.e.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Dialog.show(Unknown Source)
at com.femlab.controls.FlDialog.showAsDialog(Unknown Source)
at com.femlab.controls.FlDialog.show(Unknown Source)
at com.femlab.controls.FlModalDialog.show(Unknown Source)
at com.femlab.controls.FlDialog.showDialog(Unknown Source)
at com.femlab.gui.dialogs.z.run(Unknown Source)
at com.femlab.util.ab.run(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
This is the error I get on opensuse 64-bit whenever I try to open graphics (postprocess) or switch to mesh display. Any known cure for this? *** ERROR: Canvas3D constructed with a null GraphicsConfiguration *** This will cause a NullPointerException in a subsequent release ************************************************************************ Exception: java.lang.NullPointerException (rethrown as com.femlab.util.FlFatalException) Messages: Fatal error. - Type: NullPointerException Stack trace: at com.femlab.gui.GuiMode.a(Unknown Source) at com.femlab.gui.PostMode.a(Unknown Source) at com.femlab.gui.GuiMode.j(Unknown Source) at com.femlab.gui.at.a(Unknown Source) at com.femlab.gui.at.a(Unknown Source) at com.femlab.gui.bo.C(Unknown Source) at com.femlab.gui.an.a(Unknown Source) at com.femlab.gui.bp.run(Unknown Source) at java.awt.event.InvocationEvent.dispatch(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at com.femlab.gui.e.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.Dialog$1.run(Unknown Source) at java.awt.Dialog$3.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.awt.Dialog.show(Unknown Source) at com.femlab.controls.FlDialog.showAsDialog(Unknown Source) at com.femlab.controls.FlDialog.show(Unknown Source) at com.femlab.controls.FlModalDialog.show(Unknown Source) at com.femlab.controls.FlDialog.showDialog(Unknown Source) at com.femlab.gui.dialogs.z.run(Unknown Source) at com.femlab.util.ab.run(Unknown Source) at java.awt.event.InvocationEvent.dispatch(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at com.femlab.gui.e.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source)
Jim Freels mechanical side of nuclear engineering, multiphysics analysis, COMSOL specialist
Posted: 1 decade ago 2010/04/29 9:07 GMT-4
What hardware and OS are you guys using ? I exclusively use Nvidia graphics cards and the binary drivers that are provided by Nvidia on Linux systems (RHEL, Debian, Ubuntu). I have never had any of these problems and I do not have to resort to slower mesa drivers. Opengl works fine here.
Posted: 1 decade ago 2010/04/29 10:17 GMT-4
Our standard installation was on the dual xeon 5500 server, remote access only (XVNC). Thus, the system (opensuse) GL libraries were Mesa-7.6-3.1.x86_64.
The libs which comsol actually uses can be determined using lsof command (after comsol is started), or from the hs_err_pidXXXX.log after the system crashes.
Nvidia/ATI use different libraries, they could work better. However, using the libraries distributed with comsol seems to be safe, even if the performance can suffer.
Cyril
Our standard installation was on the dual xeon 5500 server, remote access only (XVNC). Thus, the system (opensuse) GL libraries were Mesa-7.6-3.1.x86_64. The libs which comsol actually uses can be determined using lsof command (after comsol is started), or from the hs_err_pidXXXX.log after the system crashes. Nvidia/ATI use different libraries, they could work better. However, using the libraries distributed with comsol seems to be safe, even if the performance can suffer. Cyril
Posted: 1 decade ago 2010/04/29 10:18 GMT-4
I'm running on OS Centos V (Red Hat) Dell WS 64 with java 6.0_18-b07, latest Nvidea drivers.
(my libGL.so error arrived after a java update last summer, but as I'm a "visitor" on that WS I have not bothered do to much), my colleagues running other software have no issues.
In 3 days I'm getting "my" new local WS (only for me:) will see if the error remains, and ivestigate then more. Anyhow I have been able to work, had a crash after a few graphics dump, then it was just to restart COMSOL and one could continue.
with the -mesa I hardly have any problems anymore
Hi I'm running on OS Centos V (Red Hat) Dell WS 64 with java 6.0_18-b07, latest Nvidea drivers. (my libGL.so error arrived after a java update last summer, but as I'm a "visitor" on that WS I have not bothered do to much), my colleagues running other software have no issues. In 3 days I'm getting "my" new local WS (only for me:) will see if the error remains, and ivestigate then more. Anyhow I have been able to work, had a crash after a few graphics dump, then it was just to restart COMSOL and one could continue. with the -mesa I hardly have any problems anymore Ivar
Posted: 1 decade ago 2010/04/29 10:19 GMT-4
I would recommend to try different libraries. hs_err_pidXXXX.log could give a hint. Perhaps the USEMESA=1 will work also for you.
C.
I would recommend to try different libraries. hs_err_pidXXXX.log could give a hint. Perhaps the USEMESA=1 will work also for you. C.
Posted: 1 decade ago 2010/04/29 22:09 GMT-4
Your problem is the XVNC which does not support opengl. I use NX client/server from nomachine.com. It is also much faster and convenient. Indeed, we purchased the product to improve upon the 2-user limited free server.
Posted: 1 decade ago 2010/04/30 2:32 GMT-4
it's true that the -mesa slows down drastically the save image process, but else it's OK, and its true I'm on NX "free" version, until my new WS arrives in my office
For those not wanting to have the ventilator noise there are interesting products (havnt tested it yet) like from www.teradici.com to put the heater in the basement and keep the screens on your desk
Hi it's true that the -mesa slows down drastically the save image process, but else it's OK, and its true I'm on NX "free" version, until my new WS arrives in my office For those not wanting to have the ventilator noise there are interesting products (havnt tested it yet) like from www.teradici.com to put the heater in the basement and keep the screens on your desk Ivar
Posted: 1 decade ago 2010/09/19 1:54 GMT-4
hi, all
I open a 3.5 mph file using comsol 3.5a, the error pop as following.
Mybe It is the problem about different versions.
And when I run USEMESA=1 comsol on linux terminal, no use for this condition, why?
__________________
Exception:
Fatal error.
Stack trace:
at java.lang.ref
hi, all I open a 3.5 mph file using comsol 3.5a, the error pop as following. Mybe It is the problem about different versions. And when I run USEMESA=1 comsol on linux terminal, no use for this condition, why? __________________ Exception: java.lang.NullPointerException (rethrown as com.femlab.util.FlFatalException) Messages: Fatal error. - Type: NullPointerException Stack trace: at java.lang.ref
Posted: 1 decade ago 2010/09/19 1:55 GMT-4
hi, all
__________________
Exception:
Fatal error.
Stack trace:
at java.lang.ref
Alexandre Paternoster
Posted: 1 decade ago 2011/02/10 5:34 GMT-5
I am running comsol41 and 40a from a linux machine running CentOS 5.5 (64bits).
I had a similar error when I closed the window for some users and a crash at startup for others. Both of them leading to the following error log:
# SIGSEGV (0xb) at pc=0x000000369003d118, pid=6624, tid=1088186688
# JRE version: 6.0_20-b02
# Java VM: Java HotSpot(TM) 64-Bit Server VM (16.3-b01 mixed mode linux-amd64 )
# C [libX11.so.6+0x3d118] XQueryExtension+0x28
The solution was to use the "-3drend sw" argument on launching comsol as advised by the knowledge base:
www.comsol.com/support/knowledgebase/1068/
Hoping this willl fix your error,
Alexandre.
Hi, I am running comsol41 and 40a from a linux machine running CentOS 5.5 (64bits). I had a similar error when I closed the window for some users and a crash at startup for others. Both of them leading to the following error log: # # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0x000000369003d118, pid=6624, tid=1088186688 # # JRE version: 6.0_20-b02 # Java VM: Java HotSpot(TM) 64-Bit Server VM (16.3-b01 mixed mode linux-amd64 ) # Problematic frame: # C [libX11.so.6+0x3d118] XQueryExtension+0x28 # # If you would like to submit a bug report, please visit: # http://java.sun.com/webapps/bugreport/crash.jsp # The solution was to use the "-3drend sw" argument on launching comsol as advised by the knowledge base: http://www.comsol.com/support/knowledgebase/1068/ Hoping this willl fix your error, Alexandre.
Posted: 1 decade ago 2011/02/10 21:18 GMT-5
Alexandre.
I was getting the "A fatal error has been detected by the Java Runtime Environment" and the above worked for me!
[QUOTE] The solution was to use the "-3drend sw" argument on launching comsol Alexandre. [/QUOTE] I was getting the "A fatal error has been detected by the Java Runtime Environment" and the above worked for me! Thanks
Posted: 1 decade ago 2012/02/06 15:54 GMT-5
Did you find a solution to this problem (did you intstall the Nvidia drivers and get it to work? I have a similar error even when I try comsol -3drend the error persists
"*** ERROR: Canvas3D constructed with a null GraphicsConfiguration
Exception:
Fatal error.
Stack trace:
at com.femlab.gui.au.a(Unknown Source)
at com.femlab.gui.bp.C(Unknown Source)
at com.femlab.gui.bq.run(Unknown Source)
at com.femlab.util.x.run(Unknown Source)
" I
Did you find a solution to this problem (did you intstall the Nvidia drivers and get it to work? I have a similar error even when I try comsol -3drend the error persists "*** ERROR: Canvas3D constructed with a null GraphicsConfiguration *** This will cause a NullPointerException in a subsequent release ************************************************************************ Exception: java.lang.NullPointerException (rethrown as com.femlab.util.FlFatalException) Messages: Fatal error. - Type: NullPointerException Stack trace: at com.femlab.gui.GuiMode.a(Unknown Source) at com.femlab.gui.PostMode.a(Unknown Source) at com.femlab.gui.GuiMode.j(Unknown Source) at com.femlab.gui.au.a(Unknown Source) at com.femlab.gui.au.a(Unknown Source) at com.femlab.gui.bp.C(Unknown Source) at com.femlab.gui.an.a(Unknown Source) at com.femlab.gui.bq.run(Unknown Source) at java.awt.event.InvocationEvent.dispatch(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at com.femlab.gui.e.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.Dialog$1.run(Unknown Source) at java.awt.Dialog$3.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.awt.Dialog.show(Unknown Source) at com.femlab.controls.FlDialog.showAsDialog(Unknown Source) at com.femlab.controls.FlDialog.show(Unknown Source) at com.femlab.controls.FlModalDialog.show(Unknown Source) at com.femlab.controls.FlDialog.showDialog(Unknown Source) at com.femlab.gui.dialogs.z.run(Unknown Source) at com.femlab.util.x.run(Unknown Source) at java.awt.event.InvocationEvent.dispatch(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at com.femlab.gui.e.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source) " I
Posted: 1 decade ago 2012/02/06 16:10 GMT-5
Launching Comsol using the following command avoids the mentionned error:
comsol -3drend sw
If you want to make it work without this command, you'll have to install the driver. I advise you to go on Nvidia website. In my case, I have an ATI graphic card and I found the drivers from ATI website. But, it is very difficult to keep a good configuration for a long time: each time there is an Xorg update, it breaks the driver setup.
Good luck!
Launching Comsol using the following command avoids the mentionned error: comsol -3drend sw If you want to make it work without this command, you'll have to install the driver. I advise you to go on Nvidia website. In my case, I have an ATI graphic card and I found the drivers from ATI website. But, it is very difficult to keep a good configuration for a long time: each time there is an Xorg update, it breaks the driver setup. Good luck!
