2010/10/04 10:18 GMT-4
I am a confused about what you want to do. If you want laminar flow just use laminar flow model, and make sure you use step functions for your inlet to assure a convergence (look at flow around cylinder example in comsol). Using k-e for laminar is an overkill, and does not make sense.
good luck ;)
good luck ;)
2010/10/04 21:13 GMT-4
ok.Thanks.I will try it out
2010/10/04 22:35 GMT-4
I manage to solve the convergence problem with incompressible flow.
I try and error the meshing and finally it works.
Also I include the step function which suggested by Danial,which I include umax*flc1hs(t[1/s]-0.1,0.1)-provide by cylinder flow tutorial, it give me the same result.(which I varies the meshing)
Thanks Danial.
However, when I implement the step function, it is in time dependent solver.
So, I just take the final time,t=1, in order to find the steady-state response.
Just for sharing.
Thanks.
Thanks Danial.
Just for sharing.
Thanks.
2010/10/05 2:09 GMT-4
If you are doing steady state, you won't need step function. You only need it in transient analysis.
Danial
Danial
2010/10/05 2:24 GMT-4
Thanks for Danial advice.
Means I have to varies the mesh in order to convergence in high velocity input? (for example, Vin=1.5ms-1)
2010/10/05 7:51 GMT-4
There are many parameters that influence convergence, one being mesh size. That's why you have to do mesh studies to see if your results do not vary anymore with mesh size (so you have small enough mesh). Other parameters can be the tolerances, correctness of boundary conditions, and physical correctness of the model (say you are not solving a Re of 1e6 with laminar model).
You're on the right way ;)
2012/08/15 12:06 GMT-4
Hi, I recently have encountered the similar problems like yours. Can you enunciate how you change the mesh that led to the solution to the problem?
Thank you very much
Thank you very much
