No scalar solution data on screen for cross-section quick plot
Hi, I did a system with a certain 3D geometry in wich is flowing a current. I run the simulation and the temperature results are reasonable. Then to plot the temperature VS distance graph I use the draw line for cross-section line plot and it works. Then I changed the geometry just a little bit setting again the identical boundary condition and the result of the simulation is fine, but when I use the draw line for cross-section line plot appears the message "No scalar solution data on screen for cross-section quick plot" and the graph doesn't appear.
What should I do?
thank you
0 Replies Last Post 2010/10/08 0:21 JST
Hello alberto rossi
