convergence error during simulation
Posted 2016/01/18 5:41 GMT-5 Semiconductor Devices, Mesh, Studies & Solvers Version 5.0 2 Replies
I am doing a hyperelastic simulation on a silicone rubber sheet with dimensions 50*50*5mm, with pressure being applied on the surface. But after a certain pressure range, I get this error saying:
"Failed to find a solution for all parameters,
even when using the minimum parameter step.
No convergence, even when using the minimum damping factor.
Returned solution is not converged."
What could be the possible reasons for this? I kept changing the mesh size too..but still no effect.
2 Replies Last Post 2016/04/01 16:25 GMT-4
