Strange asymetric capture on permanent magnets
I have a 3D model with permanent magnet (in shape of a cube) which captures magnetic particles on to it. However, the particles seem to get attracted to a random point on one of the edges of the magnet . Is there any reason why symmetry is lost?
I tried varying the spatial and time discretization and parameter values but found that eventually the particles got accumulated in an asymmetrical manner.
Any help will be appreciated.
Thanks!!
1 Reply Last Post 2010/10/12 2:10 GMT-4
Posted: 2 decades ago 2010/10/12 2:10 GMT-4
Depending on the mesh resolution you might have some field concentration effects along sharp edges or vertexes, that I believe could influence the flow of your particles.
Chck carefully the field pattern and use a linear mesh resolution not, a smoothened view, this might give you a clue
Hi Depending on the mesh resolution you might have some field concentration effects along sharp edges or vertexes, that I believe could influence the flow of your particles. Chck carefully the field pattern and use a linear mesh resolution not, a smoothened view, this might give you a clue -- Good luck Ivar
