2 decades ago
2010/10/14 18:21 GMT-4
have youtried the excel format export ? (havnt 4.0a on ym PC here to test)
2 decades ago
2010/10/14 22:20 GMT-4
It seems that there is no excel format export in comsol4 (Is it true?), I only find the .txt file option.
[QUOTE]
[/QUOTE]
2 decades ago
2010/10/15 0:51 GMT-4
Thank you for the answer. I tried "Spreadsheet" and "Sectionwise" data format and both didn't work. Furthermore, both data format correspond to a txt format. I don't see how to export toward a Excel format?
Thank you,
Guy
Thank you,
Guy
2 decades ago
2010/10/15 1:46 GMT-4
then its in Excel compatible txt format, try a convert data to table in Excel
2 decades ago
2010/10/15 3:03 GMT-4
Probably, I badly explained. The problem is that the txt exported file is empty and it only contains the header data such as.
But I found a solution !!!
I used a "Model Couplings" Definitions. Then, after computing, I plotted a 1D Global plot. In this case the Exported Data txt file contains all the data (header + x,y points).
Guy
Guy
2 decades ago
2010/10/16 4:45 GMT-4
Good approach.
One other thing, if you define a new coupling or operator, for postprocessing, you do not need to fully rerun your study, a: Study - SolverConfig - Solver - Solution - Update will do the job, and is mostly quicker
Good approach.
2 decades ago
2010/10/16 8:22 GMT-4
Thank you Ivar!
Guy
Thank you Ivar!
Guy
