ode and time discrete solver---week-end musing and learning
Posted 2010/10/16 8:41 GMT-4 Studies & Solvers Version 4.0a, Version 4.1, Version 4.2, Version 4.2a 4 Replies
playing with comsol new features I stumble on solving an ode with the time discrete solver.
No matter what I do [ using bdf, prev operators as explained in the doc or in the exem-le pubished by Nicklas on this forum... I ALWAYS end with duplicate variable errors and some strange variable list in the equation vie mode
for exemple if I try to solve f1'=1, f1(0)=0
I will write in the ode node
bdf(f1,1)-11 as the equation
and put the proper initial condition
I get duplicate variable error names when I try to run
but then in the comsol generated equation some "strange variable are created f1t=bdf(f1,2) GENERATED by comsol and then
f1tt=bdf(bdf(f1,2),1)) again COMSOL generated .... and apparently wrong [ derivative shoud be first order bdf according to the doc...
Does somebody know the proper way to code global ODE for use of discrete time solver?
Or is there a bug/limitation I have not seen in the doc/release note...
I should say that I have no problem coding pde... ONLY global ODE...
I attach the small file corresponding to the little example above
JF
EDIT I should add that the SAME coding as above BUT as a weak pde defined on a point on a geometry solve properly the equationbut then I need to export the solution in the glibal settting... complicated
JF
4 Replies Last Post 2012/08/08 4:24 GMT-4
