natural convection
Hi everyone,
I'm trying to make a model of natural convection in a close system (air CANNOT go in or go out), but when I start to solve there is not solution and gave the error:
Time 0:
while in a open system (air CAN go in or go out) solution is quickly given.
Can anyone help?
Best regards
Simone
4 Replies Last Post 2009/08/22 8:21 JST
Ed Fontes COMSOL Employee
Posted: 2 decades ago 2009/07/02 3:37 JST
Hi everyone,
Time 0:
Can anyone help?
Best regards
Simone
Dear Simone,
This is probably due to the pressure variable. When you have a closed system, the reference pressure for the system is undefined when using the "Incompressible Navier-Stokes". You therefore need to lock the pressure in one point.
The best approach is probably to lock the average pressure and adding a constraint on the average pressure (using a coupling variable and a global equation). However, this is an expensive solution from the computational point of view.
A possible cheap workaround is to specify the pressure variable in one point. You can do this through the following:
1. Select "Point Settings" from the "Physics" menu.
2. Select a point in the "Point selection" list
3. Check the "Point constraint" box
4. Specify a value for the pressure
5. Click "OK".
Ed
[QUOTE] Hi everyone, I'm trying to make a model of natural convection in a close system (air CANNOT go in or go out), but when I start to solve there is not solution and gave the error: Time 0: Failed to find consistent initial values. Last time step is not converged. while in a open system (air CAN go in or go out) solution is quickly given. Can anyone help? Best regards Simone [/QUOTE] Dear Simone, This is probably due to the pressure variable. When you have a closed system, the reference pressure for the system is undefined when using the "Incompressible Navier-Stokes". You therefore need to lock the pressure in one point. The best approach is probably to lock the average pressure and adding a constraint on the average pressure (using a coupling variable and a global equation). However, this is an expensive solution from the computational point of view. A possible cheap workaround is to specify the pressure variable in one point. You can do this through the following: 1. Select "Point Settings" from the "Physics" menu. 2. Select a point in the "Point selection" list 3. Check the "Point constraint" box 4. Specify a value for the pressure 5. Click "OK". Best regards, Ed
Posted: 2 decades ago 2009/07/03 17:08 JST
Dear Ed,
I'm using 'Weakly Compressible Navier-Stokes', and the floating law as a volume-force in y-direction (2 dimensional model).
I try to use 'Incompressible Navier-Stokes' and the 'Point constraint'.
Thanks a lot
Regards, Simone
Dear Ed, I'm using 'Weakly Compressible Navier-Stokes', and the floating law as a volume-force in y-direction (2 dimensional model). I try to use 'Incompressible Navier-Stokes' and the 'Point constraint'. Thanks a lot Regards, Simone
Posted: 2 decades ago 2009/07/07 21:30 JST
I tried to use 'Incompressible Navier-Stokes' and the 'Point constraint' for my model, and on my personal notebook (PC with a client-server connection) works well, but on Mac of my study (the server) it does not work.
Is possible that the same file works on a Pc and does not work on a Mac?
thanks all
Simone
Hi, I tried to use 'Incompressible Navier-Stokes' and the 'Point constraint' for my model, and on my personal notebook (PC with a client-server connection) works well, but on Mac of my study (the server) it does not work. Is possible that the same file works on a Pc and does not work on a Mac? thanks all Simone
Posted: 2 decades ago 2009/08/22 8:21 JST
Hi Ed,
Your comment was really useful for me, I was trying to model closed-end system but there was no success for a long time. I just needed to set the pressure point and it works :)
thank you.
Hi Ed, Your comment was really useful for me, I was trying to model closed-end system but there was no success for a long time. I just needed to set the pressure point and it works :) thank you.
