why is calculated initial value always different from specified one.
Ghodsiehsadat Jahanmir
Dear All,
I faced one problem in comsol. I specified one non zero initial value for a time dependent physics(tds). after solving, in post processing step, When I plot the average value of dependent variable over time, the value for initial time is always smaller from what I specified in initial value tab in model. it cause problem specially when I coupled it with Matlab. in every large time step, I run comsol, then transfer data to matlab to calculate one thing then pass it to comsol for next time step. for next time , it should use last time value but it is always smaller and it causes a sudden drop in whole profile at beginning of each time step.
any one have any suggestion?
3 Replies Last Post 2016/02/23 3:41 JST
Jeff Hiller COMSOL Employee
Posted: 9 years ago 2016/02/19 22:43 JST
The first thing I would look at is whether your initial value for the dependent variable is consistent with some of the boundary conditions. If the two are not consistent, at t=0 there will be a gradient in that dependent variable in the first element next to the boundary in question, as the software tries to reconcile the conflicting requirements, and that will cause the average to be different from the initial value specified.
If that's the problem, then the solution is to fix the underlying problem, i.e. to specify boundary conditions that are consistent with the initial condition (or vice versa, depending on the physical situation you are trying to model). For instance you could specify a time dependent boundary condition that ramps up from the initial value to a different value over a short period of time.
Just a thought. There could be other reasons.
The first thing I would look at is whether your initial value for the dependent variable is consistent with some of the boundary conditions. If the two are not consistent, at t=0 there will be a gradient in that dependent variable in the first element next to the boundary in question, as the software tries to reconcile the conflicting requirements, and that will cause the average to be different from the initial value specified. If that's the problem, then the solution is to fix the underlying problem, i.e. to specify boundary conditions that are consistent with the initial condition (or vice versa, depending on the physical situation you are trying to model). For instance you could specify a time dependent boundary condition that ramps up from the initial value to a different value over a short period of time. Just a thought. There could be other reasons. Jeff
Posted: 9 years ago 2016/02/22 20:34 JST
Dear Jeff,
Thanks for your reply. I think it is the case. because I assumed an initial non zero concentration while at border concentration is zero cause I assumed a perfect sink condition at the surrounding.
thanks so much.
[QUOTE] The first thing I would look at is whether your initial value for the dependent variable is consistent with some of the boundary conditions. If the two are not consistent, at t=0 there will be a gradient in that dependent variable in the first element next to the boundary in question, as the software tries to reconcile the conflicting requirements, and that will cause the average to be different from the initial value specified. If that's the problem, then the solution is to fix the underlying problem, i.e. to specify boundary conditions that are consistent with the initial condition (or vice versa, depending on the physical situation you are trying to model). For instance you could specify a time dependent boundary condition that ramps up from the initial value to a different value over a short period of time. Just a thought. There could be other reasons. Jeff [/QUOTE] Dear Jeff, Thanks for your reply. I think it is the case. because I assumed an initial non zero concentration while at border concentration is zero cause I assumed a perfect sink condition at the surrounding. thanks so much.
Posted: 9 years ago 2016/02/23 3:41 JST
Yes, then you'd want to specify a time dependent boundary concentration than rapidly drops from the initial value to zero. You can use one of the pre-implemented functions, or specify your own mathematical expression.
Yes, then you'd want to specify a time dependent boundary concentration than rapidly drops from the initial value to zero. You can use one of the pre-implemented functions, or specify your own mathematical expression. Jeff
