9 years ago
2016/02/22 0:53 JST
Hello? Can somebody help?
9 years ago
2016/02/23 23:29 JST
I guess I found how to do this. You need to generate three random numbers using the random function in COMSOL. Let's say these numbers are a, b, and c. Using the expression bellow you can generate components of unit vectors with random orientations. Multiply them with the magnitude of your desired vector and you get vectors with same magnitude but random orientations.
a'=a/sqrt(a^2+b^2+c^2)
b'=b/sqrt(a^2+b^2+c^2)
c'=c/sqrt(a^2+b^2+c^2)
Gunnar Andersson
COMSOL Employee
9 years ago
2016/02/24 16:12 JST
This is a decent approximation, but you don't get a uniform distribution over set of directions.
9 years ago
2016/03/03 5:42 JST
Do you know any alternatives?
[QUOTE]
[/QUOTE]
Gunnar Andersson
COMSOL Employee
9 years ago
2016/03/03 16:31 JST
For a mathematical question such as yours I think that Google is a faster way to find an answer than this forum: Search for e.g. "random vector sphere".
[QUOTE]Do you know any alternatives?[/QUOTE]
9 years ago
2016/08/17 0:48 JST
I'm having the same problem. So, let me give it a try.
Let's say the magnitude of the vector is equal to N and the direction of the vector varies with time.
For 2D simulation, I think one can create a random function (named rn1) with uniform distribution that ranges from -pi to pi (or 0 to 2*pi). By doing so, the x-compnent and y-compoent of the vector correspond to N*cos(rn1(t)) and N*sin(rn1(t)).
As for 3D simulation, I think it is just in analogy to spherical coordinate. If one creates two random functions both ranging from -pi to pi, then
x-component: N*sin(rn1(t))*cos(rn2(t))
y-component: N*sin(rn1(t))*sin(rn2(t))
z-component: N*cos(rn1(t))
Am I right about this?
Edgar J. Kaiser
Certified Consultant
9 years ago
2016/08/17 5:47 JST
No, that's not correct. Things are different on a sphere!
Being curious I followed Gunnar's advice and in less than a minute I found:
mathworld.wolfram.com/SpherePointPicking.html
wolfram.com is frequently a very good resource for mathematics.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Being curious I followed Gunnar's advice and in less than a minute I found: http://mathworld.wolfram.com/SpherePointPicking.html
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
9 years ago
2016/08/17 10:23 JST
Hi Edgar,
Thanks for your reply. I finally know how to solve problem correctly.
Hi Edgar,
