Cummulative Sum in Comsol
Is it possible to achieve (within comsol) a cumulative sum of a time varying data.
Can I use SUM in Comsol to implement that ?
Any suggestion will be appreciated !
N. N
2 Replies Last Post 2016/03/14 10:34 GMT-4
Posted: 10 years ago 2016/03/14 3:23 GMT-4
You can achieve this by adding an ODE: Suppose that you want to compute the cumulative sum (integral) of f(t). Then add the ODE d(fsum,t) = f(t). The ODE can be global or distributed.
[QUOTE]Is it possible to achieve (within comsol) a cumulative sum of a time varying data. Can I use SUM in Comsol to implement that ?[/QUOTE] You can achieve this by adding an ODE: Suppose that you want to compute the cumulative sum (integral) of f(t). Then add the ODE d(fsum,t) = f(t). The ODE can be global or distributed.
Posted: 10 years ago 2016/03/14 10:34 GMT-4
Hi Gunnar,
Thanks a lot for your help !
Best Regards
N.N
Hi Gunnar, Thanks a lot for your help ! Best Regards N.N
