Measurement points
I'm trying to model a simple heat transfer model. Can I select some measurement points on my sample and have the temperature of those points as a result?
4 Replies Last Post 2010/10/28 6:13 JST
Posted: 1 decade ago 2010/10/28 0:40 JST
After you solve your model, you can simply look at the results of the variables at a specific point.
To do this:
1. Click on 'Postprocessing' from the above menu
2. Select 'Cross-section Plot Parameters'
3. Select the 'Point' Tab
4. In the 'Expression' section, write the name of the variable of which results you want to see
5. In the 'Coordinates' section, write the coordinates of the point that you are interested in
6. Click OK
You will get the results of the selected variable on that point. If it is a transient analysis, the x-axis will be 'time'
Özen
After you solve your model, you can simply look at the results of the variables at a specific point. To do this: 1. Click on 'Postprocessing' from the above menu 2. Select 'Cross-section Plot Parameters' 3. Select the 'Point' Tab 4. In the 'Expression' section, write the name of the variable of which results you want to see 5. In the 'Coordinates' section, write the coordinates of the point that you are interested in 6. Click OK You will get the results of the selected variable on that point. If it is a transient analysis, the x-axis will be 'time' Regards, Özen
Posted: 1 decade ago 2010/10/28 0:55 JST
I'm sorry, But I couldn't find the post processing tab :( is it the same in all versions?
Thanks again for your help.
I'm sorry, But I couldn't find the post processing tab :( is it the same in all versions? Thanks again for your help.
Posted: 1 decade ago 2010/10/28 6:08 JST
For version 4.0, See Model Tree - Results
For former version, See the Menu - PostProcessing
[QUOTE] I'm sorry, But I couldn't find the post processing tab :( is it the same in all versions? Thanks again for your help. [/QUOTE] For version 4.0, See Model Tree - Results For former version, See the Menu - PostProcessing
Posted: 1 decade ago 2010/10/28 6:13 JST
Thank you so much! Since I could not find that, I did this :
Results --> data sets --> derived values --> point evaluation
It seems to do what I wanted. Thank you so much again for your help :-)
Thank you so much! Since I could not find that, I did this : Results --> data sets --> derived values --> point evaluation It seems to do what I wanted. Thank you so much again for your help :-)
