Fluid mixing in micro mixer
Posted 2016/03/19 20:01 JST Fluid & Heat, Microfluidics, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 5.1 0 Replies
I am working on a project and in one part I have use Comsol. This is the first time I am using Comsol and badly need some guidance.
I am working with a micro mixer where I have mix two fluids. In brief, first I want to fill all the channels of the mixer with DI water at a rate of 5 µl/min through inlet one and when all the channels are filled the flow is halted. Then I want to flow a higher index liquid (highly concentrated CaCl2 solution) again at a rate of 5µl/min through the second inlet. So water will be replaced by the solution of cacl2 but it will not be replaced abruptly. There will be a period of transition and the mixer will maintain a homogeneous mix of the two liquids during this period. As a result with time, change of concentration will occur. I want to monitor this change of concentration on a period of 50 second.
Being a new user I am a bit confused which physics should I use and how to couple them in time dependent condition. Any suggestion or advice in order to express my logic properly in Comsol will be great.
Thanks in advance
Haider
Hello Khondker Muzaddid Haider
