Problem on result when simulate varied force between two permmanent magnet plates
Posted 2016/03/25 13:37 GMT-4 Low-Frequency Electromagnetics, Geometry, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers Version 5.2 2 Replies
Currently, I am working on a 3D model of two permanent magnet plates (I have attached model below, the permanent magnet plates have alternating polarity). One permanent magnet plate can move in the direction parallel to the other permanent magnet plate. Now, I want to find relationship between force in motion direction and the displacement. I use AC/DC model for the magnetic field. I also use infinite elements to be the boundary. Basically, I follow the every setting of a tutorial on 3D axial magnetic bearing from COMSOL.
However, the result I have is weird (see the attachment), the plot is not smooth and even the force at 0 displacement is not 0 which should be 0 because of the symmetry. Since I am a beginner on COMSOL, I can't figure out where the problem is from. Can anyone help me on this?
Sincerely,
Xingjian Liu
Sincerely,
Xingjian Liu
2 Replies Last Post 2016/03/29 9:12 GMT-4
