Urgent: Coordinate system
Hello everybody,
Can you please let me know if we can change the coordinate system or rather define a local coordinate system in the RF module? I am using version 3.5a.
Further, please let me know as to how can we define a gaussian beam at an angle using the RF module for transient analysis.
Thanking you in anticipation,
Avineet
7 Replies Last Post 2011/03/29 18:36 GMT-4
Posted: 2 decades ago 2010/11/02 2:20 GMT-4
you can define a local coordinate system, see the doc and search on the knowledge base there are examples.
For the Gaussian beam you need normally to define the transverse Gaussian field distribution (by an equation) and the propagation vector k, but now I havent done it in 3.5 for so long that I'm already forgetting the detailes of the "old" COMSOL specialities ;)
Hi you can define a local coordinate system, see the doc and search on the knowledge base there are examples. For the Gaussian beam you need normally to define the transverse Gaussian field distribution (by an equation) and the propagation vector k, but now I havent done it in 3.5 for so long that I'm already forgetting the detailes of the "old" COMSOL specialities ;) -- Good luck Ivar
Posted: 2 decades ago 2010/11/02 12:17 GMT-4
Hello Ivar,
Thanks for your help. But it seems that it is not possible to define a local coordinate system in the RF module. Is it possible in version 4.0?
Thank you,
Avineet
Hello Ivar, Thanks for your help. But it seems that it is not possible to define a local coordinate system in the RF module. Is it possible in version 4.0? Thank you, Avineet
Posted: 2 decades ago 2010/11/04 2:44 GMT-4
yes in V4 you acn , in 3.5 then you must do it by "hand" and check that your values transformed back into the cartesian system still are valid
Hi yes in V4 you acn , in 3.5 then you must do it by "hand" and check that your values transformed back into the cartesian system still are valid -- Good luck Ivar
Posted: 1 decade ago 2010/11/05 10:04 GMT-4
Hello Ivar,
Does that mean I have to transform all the built-in equations(in the Equation System) in COMSOL to the new co-ordinate system too?
Hello Ivar, Does that mean I have to transform all the built-in equations(in the Equation System) in COMSOL to the new co-ordinate system too? Thanks
Posted: 1 decade ago 2010/11/05 10:30 GMT-4
Hello Ivar,
Is it possible to change the k (wave direction) in the 3.5 version of COMSOL? If yes, how do I change the wave direction?
Further, do I transform the equations written in the expression option itself or elsewhere? I need to chenge the wave direction somehow and I am not getting how to do it.
Thanks a lot,
Avineet
Hello Ivar, Is it possible to change the k (wave direction) in the 3.5 version of COMSOL? If yes, how do I change the wave direction? Further, do I transform the equations written in the expression option itself or elsewhere? I need to chenge the wave direction somehow and I am not getting how to do it. Thanks a lot, Avineet
Posted: 1 decade ago 2010/11/05 14:33 GMT-4
Thanks a lot Ivar.
I finally got an inclined beam.
Avineet
Thanks a lot Ivar. I finally got an inclined beam. Regards, Avineet
Posted: 1 decade ago 2011/03/29 18:36 GMT-4
Hi Avineet,
Could you please say how to define a gaussian beam in RF module, as you have already worked on it.
and also to give inclination.
Hi Avineet, Could you please say how to define a gaussian beam in RF module, as you have already worked on it. and also to give inclination.
