Hello vin Ga
9 years ago
2016/10/27 16:12 JST
Hello Vin Ga ;
I worked on a similar model before , unfortunately i cant attach it.
first of all u need to make sure that the material properties you are using (SF6) is a function of Temperature/Pressure.
2nd; start the physics one by one , try first the EC ( electric current ) alone then add the ht ( heat transfer in fluids ) . to couple between ec and ht , use the multiphysics node automatically provided by COMSOL , then add temperature coupling and the heat source which u would like to include .
later add the flow , and add the temperature coupling and flow coupling from the multiphysics node.
i hope this will be helpful.
Hello Vin Ga ;
