A Basic Q regarding the Solver Manager
Posted 2010/11/06 8:21 GMT-4 4 Replies
Hi!
This is likely to be a trivial question, but I haven't managed to sort out the answer by myself...
I'm using a 2D structural mechanics smpn module.
I'm working on Comsol 3.5a and 4.a, but I'd rather work on version 3.5a in this case.
My Q is pretty general, but for the record I'll just say I'm trying to solve a very simple geometry (a square) of a viscoelastic material. Thus, I'm using the Time Dependent Solver.
I would like to:
1) Solve with a time dependent solver with range(1,0.001,1.5) + a certain deformation gradient (which I had defined under Global expressions).
2) BASED on the former solutions from the first solver, I would like to use a second time dependent solver with a new range(1.5, 0.001, 2) + a different deformation gradient (which means that this time I would like to change some values under global expressions).
In short, I would like to solve a problem using one solver with a certain range, store these solutions and based on these solutions stored to use a second solver, with a continuous range and a changed variable.
I know the answer hides under "Solver Manager" and "Sequential Solver". However, I've already read about it in the help section and unfortunately, nothing seems to work.
Can anyone PLEASE tell me what steps should I take in order for this to work?
Thank you very much,
Tal
I would like to:
Tal
4 Replies Last Post 2010/11/08 7:45 GMT-5
