access a result value within the model to generate force
Posted 2016/04/15 14:22 GMT-4 Parameters, Variables, & Functions Version 5.2 4 Replies
Hi all,
I need to find the pressure difference above and below a shell, along one of its edges, then use it to generate point load on another part of my model.
1. I define a variable of dp_shell with up(p)-down(p) on that boundary
2. I define another variable of dp_edge, using dp_shell on its edge
Now when I define point load of a*dp_edge, I receive an error of undefined variable.
Is it because the variable is not defined before solution?
Do you have an alternative suggestion to apply the load, based on the pressure difference on sides of the boundary, along one of its edges?
4 Replies Last Post 2016/04/15 16:41 GMT-4
