Comsol 3.5 - RF module - Eigenfrequency - Why do I have a factor ' - 2 * i * pi' ?
Using Comsol 3.5 RF module with Matlab, I already found that you need to put the frequency multiplied by ' - 2 * i * pi' in the solver line (and you need to divide by the same factor the solutions you get to have the real frequencies).
The problem is now I want to import the fem structure calculated with Matlab in Comsol, to have a better vision of the solutions. But the different solutions have frequencies multiplied by ' - 2 * i * pi', whereas the same structure calculated only with Comsol has the 'right' value of frequencies.
It seems using a script is the reason for this factor, but is there a way to access the real frequencies when importing a fem structure calculated with Matlab ? I tried 'naively' to change the values of the solutions before importing, but I get the "Access to an object's fields is only permitted within its methods" error. Anyone has an idea ?
Thank You.
2 Replies Last Post 2010/11/10 3:31 JST
Posted: 1 decade ago 2010/11/10 0:23 JST
are you sure you have selected eigenfrequency in frequency mode and not eigenvalue mode ?
Hi are you sure you have selected eigenfrequency in frequency mode and not eigenvalue mode ? -- Good luck Ivar
Posted: 1 decade ago 2010/11/10 3:31 JST
Actually, it is the exactly the opposite I should do, I need to use eigenvalues to have the real frequency values and not eigenfrequencies (I just tested, it works). But I wouldn't have thought of it if you didn't mention it, so thank you :D.
Now why the real frequency are eigenvalues and not eigenfrequencies with a Matlab script, I have no idea. At least if you know it, it works very well.
Hi, Actually, it is the exactly the opposite I should do, I need to use eigenvalues to have the real frequency values and not eigenfrequencies (I just tested, it works). But I wouldn't have thought of it if you didn't mention it, so thank you :D. Now why the real frequency are eigenvalues and not eigenfrequencies with a Matlab script, I have no idea. At least if you know it, it works very well.
