Evaluate parameter value in MATLAB
If I have a parameter, e.g.:
>> model.param.set('outer_z', '((volume*formfactor^2)/(2*pi))^(1/3)');
How can I in the easiest way evaluate the value of this parameter (like the 'Value'-column in the GUI)?
I get an error message when trying to use:
>> mphglobal(model,'outer_z')
"com.comsol.util.exceptions.FlException: Unknown dataset feature"
Johan
8 Replies Last Post 2015/10/02 5:19 GMT-4
Hello Johan Gustafsson
Posted: 1 decade ago 2010/12/28 3:34 GMT-5
Did you figure it out?
Posted: 1 decade ago 2011/01/04 13:35 GMT-5
No, unfortunately I have not. I worked around the problem by calculating the variables in MATLAB first and then assigning the final value to the COMSOL model. But it would still be nice to be able to get this to work.
Johan
No, unfortunately I have not. I worked around the problem by calculating the variables in MATLAB first and then assigning the final value to the COMSOL model. But it would still be nice to be able to get this to work. Johan
Posted: 1 decade ago 2011/12/21 6:38 GMT-5
Johan
The function mphglobal(model,'parameter_name') works for me when calculating parameter values. Maybe there is a problem in your definition of ((volume*formfactor^2)/(2*pi))^(1/3), check that all the parameters are set.
Bye.
[QUOTE] Hi, If I have a parameter, e.g.: >> model.param.set('outer_z', '((volume*formfactor^2)/(2*pi))^(1/3)'); How can I in the easiest way evaluate the value of this parameter (like the 'Value'-column in the GUI)? I get an error message when trying to use: >> mphglobal(model,'outer_z') "com.comsol.util.exceptions.FlException: Unknown dataset feature" Regards, Johan [/QUOTE] The function mphglobal(model,'parameter_name') works for me when calculating parameter values. Maybe there is a problem in your definition of ((volume*formfactor^2)/(2*pi))^(1/3), check that all the parameters are set. Bye.
Andrew Prudil Nuclear Materials
Posted: 1 decade ago 2013/04/12 13:07 GMT-4
Hi everyone,
Sorry for bring back such an old discussion but I'm having the same problem (unknown data set). I think this problem somehow relates to having not initialized the model (but I'm not sure how). Since it cannot find a dataset to evaluate the string in. Anyone know what I'm missing? Consider the simple striped down MATLAB script below which returns the same error. Interestingly enough model.param.get('test_param_a') will return the original string.
Thanks in advance,
Andrew
import com.comsol.model.*
import com.comsol.model.util.*
model = ModelUtil.create('Model');
model.modelPath('F:\FAST\MATLAB');
model.modelNode.create('mod1');
model.geom.create('geom1', 2);
model.geom('geom1').axisymmetric(true);
model.mesh.create('mesh1', 'geom1');
model.param.set('test_param_a', '1[mm]');
temp = mphglobal(model,'test_param_a')
Hi everyone, Sorry for bring back such an old discussion but I'm having the same problem (unknown data set). I think this problem somehow relates to having not initialized the model (but I'm not sure how). Since it cannot find a dataset to evaluate the string in. Anyone know what I'm missing? Consider the simple striped down MATLAB script below which returns the same error. Interestingly enough model.param.get('test_param_a') will return the original string. Thanks in advance, Andrew import com.comsol.model.* import com.comsol.model.util.* model = ModelUtil.create('Model'); model.modelPath('F:\FAST\MATLAB'); model.modelNode.create('mod1'); model.geom.create('geom1', 2); model.geom('geom1').axisymmetric(true); model.mesh.create('mesh1', 'geom1'); model.param.set('test_param_a', '1[mm]'); temp = mphglobal(model,'test_param_a')
Posted: 1 decade ago 2014/03/10 13:16 GMT-4
Johan
I'm also having the same problem, has anyone figured this out?
Mark
[QUOTE] Hi, If I have a parameter, e.g.: >> model.param.set('outer_z', '((volume*formfactor^2)/(2*pi))^(1/3)'); How can I in the easiest way evaluate the value of this parameter (like the 'Value'-column in the GUI)? I get an error message when trying to use: >> mphglobal(model,'outer_z') "com.comsol.util.exceptions.FlException: Unknown dataset feature" Regards, Johan [/QUOTE] I'm also having the same problem, has anyone figured this out? Thanks, Mark
Posted: 1 decade ago 2014/03/10 13:41 GMT-4
It has been a while since I worked with the LiveLink for Matlab. To get a parameter (pellet_length) from Comsol to Matlab I used the following commmand:
pellet_length = mphevalglobalmatrix(model,'pellet_length');
Not sure if this applies only to parameters, or if there is a better way of doing this, but it worked for me.
It has been a while since I worked with the LiveLink for Matlab. To get a parameter (pellet_length) from Comsol to Matlab I used the following commmand: pellet_length = mphevalglobalmatrix(model,'pellet_length'); Not sure if this applies only to parameters, or if there is a better way of doing this, but it worked for me.
Posted: 1 decade ago 2014/03/10 16:01 GMT-4
Andrew. Thanks a lot! It turns out that I was able to get
to work too. So it appears I'm in good shape now.
Thanks!
Mark
[QUOTE] It has been a while since I worked with the LiveLink for Matlab. To get a parameter (pellet_length) from Comsol to Matlab I used the following commmand: pellet_length = mphevalglobalmatrix(model,'pellet_length'); Not sure if this applies only to parameters, or if there is a better way of doing this, but it worked for me. [/QUOTE] Andrew. Thanks a lot! It turns out that I was able to get mphglobal(model,'outer_z') to work too. So it appears I'm in good shape now. Thanks! Mark
Posted: 1 decade ago 2015/10/02 5:19 GMT-4
model.param.get('outer_z') should work
