Documentation for setting up model in 4a version
I am a new COMSOL user and had been using 3.5a version until now (structural mechanics module). Just as I got used to the 3.5a version I was told that I can work better with version 4a. I have been trying to transfer my work in version 3.5a to version 4 but it has not been easy to understand how the model is set up in version 4. Apart from example models is there detailed documentation available some place on how to set up a model in v 4?
SA
1 Reply Last Post 2010/11/16 15:37 GMT-5
Posted: 1 decade ago 2010/11/16 15:37 GMT-5
You will be even better servec in the newer 4.1 though. I agree its not trivial to go from 3.5 to 4, and some of the translated file become extensively complex.
The best I can propose is to start from scratch in V4 and start simple with i.e. the tutorial case. After a few days I'm sure you will be able to catch the logic, even of your more complex 3.5 models when loaded into V4
And after a week's time I bet, you will certanly no longer want to go back to 3.5, as most of us feel ;)
Hi You will be even better servec in the newer 4.1 though. I agree its not trivial to go from 3.5 to 4, and some of the translated file become extensively complex. The best I can propose is to start from scratch in V4 and start simple with i.e. the tutorial case. After a few days I'm sure you will be able to catch the logic, even of your more complex 3.5 models when loaded into V4 And after a week's time I bet, you will certanly no longer want to go back to 3.5, as most of us feel ;) -- Good luck Ivar
