Fluid-Thermal Interacion Module
Posted 2009/10/12 11:55 GMT-4 1 Reply
I am trying to simulate the temperature and velocity distribution the following model:
Geometry : 2D representation of a tube
Left Opening : Air entering at velocity of 10m/s, T=320 K.
Wall : Insulated
Right Opening : Open to surrounding temperature of 300K. Pressure = 1 atm .
What would be the correct boundary setting for the right opening? Is it correct to set the left boundary to Temperature, 320 K, U = 10 m/s ?
Also, I have some trouble solving the model when I load the library model for air in the subdomain setting. It seems that some expressions are unable to be evaluated. There don't seems to be a problem when I use constant value instead of library material. Is it because I make some error in boundary values or initial values? Or is there some constants that I need to define to use the library material?
Wall : Insulated
1 Reply Last Post 2009/10/13 5:14 GMT-4
