Solution dependent property
I'm trying to find out how to build a model where material properties depend on the solution. My problem specifically is that I'm trying to build an acoustic model, where the speed of sound of the medium (property) depends on the local pressure amplitude (solution). I'm trying to do this with the acpr module. Simply writing an expression in function of p in the field provided results in an error.
Thanks for any help on this matter.
1 Reply Last Post 2011/08/30 23:49 JST
Hello Arne Flachet
Posted: 1 decade ago 2011/08/30 23:49 JST
I have a similar request right now.
The relative permeability of nickel depends on the magnetic flux density which is a solution of the problem (magnetic fields analysis).
Thus I try to handle a non-linearity in the governing equations...
How can I fix this?
Thx a lot
I have a similar request right now. The relative permeability of nickel depends on the magnetic flux density which is a solution of the problem (magnetic fields analysis). Thus I try to handle a non-linearity in the governing equations... How can I fix this? Thx a lot
