Calculating flux in more than 100 cutlines in 2D
I have a 2D model that I have to study the flux distribution in it (not B). I drew a cut line and used ''Additional parallel lines'' in that cut line to draw more lines. when I integrate over that cut line using line integration COMSOL give me just one number ( in wb/m). In fact I expect one number for each parallel cut line. How can I solve this problem? I do not want to do this manually, because they are more than 100 lines !
Regards
Hamid
5 Replies Last Post 2016/05/25 3:31 JST
Jeff Hiller COMSOL Employee
Posted: 9 years ago 2016/05/24 23:46 JST
Hello Hamid,
Several ways of achieving what you want are presented on the COMSOL Blog:
www.comsol.com/blogs/maximum-evaluations-on-parallel-sections/
Yet another way is to create a method in an app. That assumes that you have version 5.0 or later on Windows. Big picture: repetitive post-processing (or pre-processing, for that matter) tasks are often extremely easy to automate using a method in an app.
Hello Hamid, Several ways of achieving what you want are presented on the COMSOL Blog: https://www.comsol.com/blogs/maximum-evaluations-on-parallel-sections/ Yet another way is to create a method in an app. That assumes that you have version 5.0 or later on Windows. Big picture: repetitive post-processing (or pre-processing, for that matter) tasks are often extremely easy to automate using a method in an app. Best, Jeff
Posted: 9 years ago 2016/05/25 1:12 JST
Thanks Jeff
That was great. I think I understand everything there except 'quickz'.In my case, since it is a 2D model I will replace cpl1 with cln1. The u should be converted to mf.normB in linear mode (1). But what is quickz?
Regards
Hamid
P.S.: I paste the program for quick reference.
z = [z1 z2 z3 zn];
for i = 1:length(z)
model.result.dataset('cpl1').set('quickz', z(i));
umax(i) = mphmax(model,'u',2,'dataset','cpl1');
end
plot(z, umax)
Thanks Jeff That was great. I think I understand everything there except 'quickz'.In my case, since it is a 2D model I will replace cpl1 with cln1. The u should be converted to mf.normB in linear mode (1). But what is quickz? Regards Hamid P.S.: I paste the program for quick reference. z = [z1 z2 z3 zn]; for i = 1:length(z) model.result.dataset('cpl1').set('quickz', z(i)); umax(i) = mphmax(model,'u',2,'dataset','cpl1'); end plot(z, umax)
Posted: 9 years ago 2016/05/25 3:06 JST
Hello Hamid,
You're basically asking COMSOL to define the cut plane data set using a plane specified quickly by its being normal to the z direction at the z-coordinate z(i), as opposed to the more general ways of defining a cut plane (with 3 points or, alternatively a point and a normal). If the above is not so clear, please take a look at the GUI interface for creating a cut plane and you'll see what I mean.
Hello Hamid, You're basically asking COMSOL to define the cut plane data set using a plane specified quickly by its being normal to the z direction at the z-coordinate z(i), as opposed to the more general ways of defining a cut plane (with 3 points or, alternatively a point and a normal). If the above is not so clear, please take a look at the GUI interface for creating a cut plane and you'll see what I mean. Best, Jeff
Posted: 9 years ago 2016/05/25 3:11 JST
Hi Jeff
Actually, I'm working in 2D. It does not make sence for a line. Also I do not want ot create any thing, I just want to switch from one line to another.
Regards
Hamid
Hi Jeff Actually, I'm working in 2D. It does not make sence for a line. Also I do not want ot create any thing, I just want to switch from one line to another. Regards Hamid
Posted: 9 years ago 2016/05/25 3:31 JST
Indeed, in your 2D case, things will be slightly different from the 3D example in the blog, although the general approach is the same. You do need to create data sets though.
Indeed, in your 2D case, things will be slightly different from the 3D example in the blog, although the general approach is the same. You do need to create data sets though. Best, Jeff
