Unknown Function or Operator
Posted 2016/06/16 8:44 JST Parameters, Variables, & Functions Version 5.2 3 Replies
I've searched through the forums and found several discussions with a similar error, but none of the proposed solutions have helped me.
Under Component 1, I have defined a maximum operator maxop1 over a single domain. I have used this to make a global definition for Tmax, as maxop1(comp1.T). This is the maximum temperature found in the desired domain. Then, I define a piecewise function pw1 with Tmax as the argument. Finally, I use this in a Boundary Heat Source for Component 1, with the argument as pw1(Tmax).
The Boundary Heat Source node seems to accept this argument, but when I go to compute the model, I get the following error.
"Unknown function or operator.
- Name: maxop1
- Feature: Time-Dependent Solver 1 (sol1/t1)"
If anyone has helpful input, it would be much appreciated.
- Name: maxop1
3 Replies Last Post 2016/06/17 4:32 JST
