3D generator in transient AC/DC
I would like to make a transient model of an electric generator/motor in order to calculate motor properties and simulate eddy currents as well. I'm having problems with getting the moving mesh working, and implementing periodic conditions and weak constraints. (v4.0)
Does enyone have a simple example how to implement moving mesh in AC/DC ?
Thank you!
5 Replies Last Post 2011/05/24 23:39 JST
Posted: 1 decade ago 2010/11/29 22:46 JST
Unfortunately I do not have any example, and you are heading for a complex project there, so I can only advise do it in steps: add physics one by one after the rest is solving OK.
Then really get hands on a v4.1 and update it to latest patch levle, as there are several weaknesses in 4.0 that will make life tougher than necessarily for you
Hi Unfortunately I do not have any example, and you are heading for a complex project there, so I can only advise do it in steps: add physics one by one after the rest is solving OK. Then really get hands on a v4.1 and update it to latest patch levle, as there are several weaknesses in 4.0 that will make life tougher than necessarily for you -- Good luck Ivar
Posted: 1 decade ago 2010/11/29 23:38 JST
Thank you for your answer, it's good to know i'm not imagining problems.
Are there tutorials for rotating machinery in AC/DC module of 4.1?
Thank you for your answer, it's good to know i'm not imagining problems. Are there tutorials for rotating machinery in AC/DC module of 4.1?
Posted: 1 decade ago 2010/11/30 0:08 JST
havent found so far but I have not really been searching ;)
as there were in 3.5a, they will come in V4 too qustion of time.
Now, if you are used to 3.5a then by starting very simple you should be able to get there in V4 too (perhaps trying first to import a 3.5a model to see how COMSOl translates it and then rebuild a model in v4 from scratch using the translated one as example (i.e. ignore point constraints imported by COMSOL, I have noticed these are not needed, typical example of heritage property transmission)
Hi havent found so far but I have not really been searching ;) as there were in 3.5a, they will come in V4 too qustion of time. Now, if you are used to 3.5a then by starting very simple you should be able to get there in V4 too (perhaps trying first to import a 3.5a model to see how COMSOl translates it and then rebuild a model in v4 from scratch using the translated one as example (i.e. ignore point constraints imported by COMSOL, I have noticed these are not needed, typical example of heritage property transmission) -- Good luck Ivar
Posted: 1 decade ago 2011/05/24 23:32 JST
As I know up to now Comsol can not solve 3D transient FEM for rotating machinery. This is actually weak point of Comsol, even Comsol 4.2. I hope I am wrong.
Good luck.
Hung.
Hi, As I know up to now Comsol can not solve 3D transient FEM for rotating machinery. This is actually weak point of Comsol, even Comsol 4.2. I hope I am wrong. Good luck. Hung.
Posted: 1 decade ago 2011/05/24 23:39 JST
have you tried to add a transient PDE to your problem, even if the ACDC does not solve for the transient, in many cases you can run the ACDC in stationary and run the solid in transient and still get a reasonnable solution, as the ACDC is mostly "instantenous " w.r.t the "slow" mechanics
Hi have you tried to add a transient PDE to your problem, even if the ACDC does not solve for the transient, in many cases you can run the ACDC in stationary and run the solid in transient and still get a reasonnable solution, as the ACDC is mostly "instantenous " w.r.t the "slow" mechanics -- Good luck Ivar
