New user, New software, New errors (mechanical problem)
Posted 2016/06/24 21:37 JST Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers, Structural Mechanics Version 5.2 2 Replies
I have started using comsol two weeks ago for my research and I'm a little bit disappointed. I had a first contact with this software during my studies and i remember a taste of "it never converge !".
So i usually use ANSYS but i thought COMSOL will be better for a young researcher because of the more "mathematical" environment and all the manual things you have to do in this software (control the computation, optimize the mesh at strategical position, define the boundary contact, only use coherent physical parameters...) that ANSYS could do for you, and so you don't really know what you are really doing.
To learn i do a solid mechanics 2D model to define contact between aluminium and steel, I do my own model based on the comsol template "cylinder roller contact" but i just converge the computation one time for a couple of parameters. It doesn't converge if i change values of parameters like the pressure, the dimension or even the mesh ... i can't verify if my model is just coherent with the physic. So i come back to the template and it's the same, the model converges only for a couple of values, if you change something it doesn't works. They also had to define a good initial contact pressure to make the model stable and they finally verified the answer values with analytic because it's a really simple case.
So why this model is so fragile ? if you don't use symmetry, change geometry, change dimension, increase/decrease the load, change the mesh ... it doesn't converge. THERE IS NO INTEREST. The error looks basic: Failed to find a solution.
Maximum number of segregated iterations reached.
In Segregated Step:
There was an error message from the linear solver.
The relative residual (0.002) is greater than the relative tolerance.
- Feature: Stationary Solver 1 (sol1/s1)
My ideas are:
- contact is really hard to compute,
- comsol has not enough robust solver for this,
- i miss something,
Could you help me on this please ? Be indulgent it's my first model.
In Segregated Step:
My ideas are:
- i miss something,
2 Replies Last Post 2016/06/27 19:56 JST
