BC contains dependent variable evaluated at boundary
Posted 2016/06/25 15:21 GMT-4 Version 5.2 1 Reply
Hi All,
I am trying to solve a 1-D steady state differential equation. One of the boundary condition (BC) is such that I am trying to evaluate the dependent variable at the boundary.
BC: Flux @ boundary 1 = f(dependent variable) @ boundary 1
I read in another discussion that using projection operators may do the trick.
However I tried using linear extrusion, general extrusion as well as the projection operators. None of these seem to evaluate the BC correctly which includes evaluation of dependent variable at the boundary.
Would appreciate if someone gives me a hint and if I am on the right path to solve the problem.
Thank you
Vishnu
Thank you
Vishnu
1 Reply Last Post 2016/06/27 8:54 GMT-4
