2010/12/03 15:23 JST
I suspect that you are using the solver in automatic mode, this is NOT ideal for periodic signals, as the next step is estimated from the last AND the last gradients wich might give COMSOL the feeling that we are in a steady state situation and it will propose a long step, that might again arrive at the pulse "on" state (no gradient change) and so on.
for this you have the stepping settings in the solver, either "automatic" (default but not the best for periodic signals), "strict" = the time steps you define and "intermediate" (the one I use for periodic singnals) because COSMOL tries to add an intermediate step inbetween each of the one I define.
for your type of signals with steep turn on and turn off, you should also have a stepping time sequence to sample niceley in the steep regions.
The default automatic Comsol settings are rather for a transient system that settles out in time
Check the log tab during the solver you will see te intermediate steps COMSOL takes and how they evolve. By the way by default COMSOL only saves the solutions you ask for, but you can also ask it to save ALL steps it's performing.
Last point, when solving a system that does finally NOT converge after some time, you might well have valid resultsfr the first time steps, but I have noticed that often the 2-3 last tend to deviate strongly from reasonnable results, so its not only the step that did not converge that is out of scope, be aware
2010/12/09 2:39 JST
Ivar,
I have set "Time steps taken by solver" to intermediate.
When I run my simulation for 90 seconds (exactly 3 periods of my above function) I get about the same results as I did before. If I run the simulation for any longer it diverges.
I tried changing the "maximum time step" under time step tuning to 0.01, but then my simulation diverged very quickly (around 8 seconds) instead of after the 90 seconds.
Is there some other parameter that needs tweaking for the intermediate setting to work?
Nick
Ivar,
Nick
2010/12/09 4:46 JST
no normally not, that should do, so obviously you have some energy entering, but not enough leaving out to get an equilibrium.
I'm not sure what to suggest (apart to run over you model once again and check the material properties (are all defined) the physics and the BC's
2010/12/11 1:04 JST
I have one material that is not defined, but I have defined all of its parameters.
How should I be tweaking the time step tuning? I have my maximum time step set to auto, which is 0.1
My initial time step is also set to auto which is 0.001
