S-Parameters in Microwave Cavity
Is it normal having a -30dB magnitude of S11 in a certain frequency, even if the the Microwave Cavity (Aluminum) is empty? What does it mean exactly? It could be the some parts of the cavity absorbs the MWs.
4 Replies Last Post 2016/08/30 2:58 JST
Posted: 9 years ago 2016/08/26 23:49 JST
Did you apply PEC or impedance boundary condition on cavity wall? Perform surface integration of power density at cavity wall to determine power absorption by wall.
Posted: 9 years ago 2016/08/27 0:54 JST
Dear Sohan, Thanks for your attention, first I have assigned the cavity walls PEC then I have changed them into Impedance boundaries, because I also added the heat transfer in solids and convective heat flux for the outer surface of the cavity. More or less I followed the example of RF Heating.
Posted: 9 years ago 2016/08/30 0:40 JST
Integrate the power absorbed in wall and load. Then determine the absolute value of S11 parameters any point on surface of the domain. Inpt_power*(1-abs(S11)^2) should be equal to integrated power. If this numbers are different than check for mesh quality. Let the software select the meshing scheme.
Posted: 9 years ago 2016/08/30 2:58 JST
I suppose that I have to do these integrations at one fixed frequency, right?
