2010/12/21 2:40 GMT-5
I have also niticed that COMSOL adds many file in your "profile", I have understood these are related to the help files and the indexing thereof (not sure). Unfortunately I have no info on how to change that, but try to ask support.
As I do not have a "roaming profile" on my PC I do not have any great problem, but I'm an exception at work and it is true that if I had had a roaming profil my IP administrator would have blocked the use of COMSOL for a long time ago, so it is somewhat a nuisance I agree
2010/12/21 7:00 GMT-5
Well,
especially i find the roaming can be disastrous if a very small home directory is allocated by the IP manager
of the working place, which is less than 1 G in my case.
Sometimes the COMSOL solving process will be terminated because the continuously growing size of the directory
'bundles' used up all my home directory then gives 'disk quota exceeded' error.
currently , the only way i am using is running a bash script which is monitoring the existence of the directory 'bundles' and deleting it
as soon as it appears. It seems that it works out quite well without any problems.
Well,
2010/12/21 7:11 GMT-5
you should report this to "support" as it's of general importance as a "strong" suggestion for next release (to use the temp folders and not the profile)
2010/12/22 8:27 GMT-5
I have the same problem and asked the support today. If someone gets a solution early then I, please be so kind and post it. When I get a solution, I will post it.
kind regards,
Martin Siegele
kind regards,
Martin Siegele
2010/12/23 9:29 GMT-5
COMSOL Support:
The '.comsol\configuration' and '.comsol\workspace' folders can be moved to another location by changing the following lines in the 'COMSOL41\bin\win64\comsol.ini' file:
-Dosgi.configuration.area=@user.home/.comsol/v41/configuration/comsol
-Dosgi.instance.area=@user.home/.comsol/v41/workspace/comsol
to read, for example:
-Dosgi.configuration.area=C:/Temp/comsol/v41/configuration/comsol
-Dosgi.instance.area=C:/Temp/comsol/v41/workspace/comsol
In case you are running 32-bit COMSOL, this ini file is 'COMSOL41\bin\win32\comsol.ini' instead.
COMSOL Support:
Jim Freels
mechanical side of nuclear engineering, multiphysics analysis, COMSOL specialist
2010/12/26 8:19 GMT-5
There is also a tmp switch you can add on the command line that may take care of some of the larger files that get created during a typical COMSOL execution.
2011/01/07 1:22 GMT-5
I am having a problem which might sound familiar to people discussing the original topic. Although I just posted it to support, I will appreciate if there can be a quick reply here.
For some reason related to the organization of our linux cluster, I have to change $HOME from the regular /home/shakeeb/ to a new location /lustre/vol/shakeeb. All applications I have used until now used to notice this change without any trouble. However, Comsol 4.0a has some issues with it as it still tries to access /home/shakeeb/ which is no longer available. I even tried -tmpdir switch but no avail. As a result, I always get the following error:
-bash-3.2$ HOME=/lustre/vol/shakeeb/
-bash-3.2$ export HOME
-bash-3.2$ echo $HOME
-bash-3.2$ /cluster/comsol40a/bin/comsol server -np 12 -mpmode owner
!SESSION 2011-01-07 06:28:06.246 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_20
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: server -install ../.. -np 12 -mpmode owner
Command-line arguments: -os linux -ws gtk -arch x86_64 server -install ../.. -np 12 -mpmode owner
!ENTRY org.eclipse.osgi 4 0 2011-01-07 06:28:06.634
!MESSAGE Error reading configuration: /home/shakeeb/.comsol/v40a/configuration/comsol/org.eclipse.osgi/.manager/.fileTableLock (No such file or directory)
!STACK 0
java.io.FileNotFoundException: /home/shakeeb/.comsol/v40a/configuration/comsol/org.eclipse.osgi/.manager/.fileTableLock (No such file or directory)
at java.io.RandomAccessFile.open(Native Method)
at java.io.RandomAccessFile.<init>(Unknown Source)
at org.eclipse.core.runtime.internal.adaptor.Locker_JavaNio.lock(Locker_JavaNio.java:32)
at org.eclipse.osgi.storagemanager.StorageManager.lock(StorageManager.java:388)
at org.eclipse.osgi.storagemanager.StorageManager.open(StorageManager.java:686)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.initFileManager(BaseStorage.java:213)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.initialize(BaseStorage.java:147)
at org.eclipse.osgi.baseadaptor.BaseAdaptor.initializeStorage(BaseAdaptor.java:121)
at org.eclipse.osgi.framework.internal.core.Framework.initialize(Framework.java:185)
at org.eclipse.osgi.framework.internal.core.Framework.<init>(Framework.java:157)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:286)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:175)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
Username: shakeeb
Password:
Confirm password:
ERROR: Could not start COMSOL Application. See log file: null
!STACK 0
at java.io.RandomAccessFile.(Unknown Source)
at org.eclipse.osgi.framework.internal.core.Framework.(Framework.java:157)
Username: shakeeb
Password:
Confirm password:
2011/01/07 2:10 GMT-5
often its quicker to reinstall the software, and COMSOL is rather easy to install. Note that you should get hands on the latest version, its much smoother, check with your COMSOL rep
2011/01/07 5:04 GMT-5
I am afraid re-installing the software won't redress the problem. To explain it further, I log into the front end of cluster and there all users have their home directories as /home/user. Comsol is installed at front end so it also sees that /home/user is the default directory.
Then I submit a job to queue scheduler. If a slot is empty, the job gets into execution and *then* it realizes that /home/user which was available before is not mounted anymore. That is why before starting actual job, I manually modify $HOME variable to reflect this change. However, Comsol is adamant upon using the old one.
Any tips, tricks or solution :)
2011/01/07 5:08 GMT-5
best is to ask support ;)
2011/05/20 8:47 GMT-4
Hi !
I have faced similar problem!
When running long calculation, the folder /.comsol (under Linux) becomes huge due to the continues saving of the COMSOL recovery files.
This is annoying when you have a quota for your home/user directory.
A simple solution is to switch off the option "save recovery file" and the files are not created anymore. Don't forget to restart COMSOL after changing this option.
I hope it helps
Cheers
Hi !
I hope it helps
Cheers
2011/05/20 8:51 GMT-4
For changing the location of the tmp folder, which can also get bigger if running long calculation, try:
comsol -tmpdir /new_location/tmp
This can be found in the Doc!
Cheers
Cheers
2011/05/25 3:43 GMT-4
To move the Bundles files to another location, perform the changes suggested by nitram but do the changes to
COMSOLCLASSKIT.ini instead. Changes to the COMSOL.ini file does not change the location of the Bundles directory.
2011/06/08 14:49 GMT-4
Hi I am having the exact same problem. (Although for me it is creating Recovery files which are much too large and consequently force my program to quit prematurely.) Did you receive any information about how to fix this?
Sorry double post.
Sorry double post.
2011/07/28 15:43 GMT-4
After trying several times, I find the solution as follows,
Comsol 4.1 temporary files are saved into the system defaut temporary folder, which is specified by the system environment variable of tmp. So in order to save the temporary files such as the big solution files into another folder, we can change the system environment variable, tmp.
For example, if we want to save these big files into D:\Temp, we can create a dos batch file comsol_myrun.cmd in the folder where we can find comsol.exe, the main file to run comsol, the content of the file is as follows,
set tmp=D:\Temp
start comsol.exe
If you want, you can create a shortcut for this .cmd file on your desktop. When you run comsol by double clicking on this shortcut or the .cmd file, comsol will create a subfolder like D:\Temp\cs<xxxxx> to save big temporary files such as mesh, solution, model files, and D:\Temp\hsperfdata_<username> to save other information, where <xxxxx> is a five digit random number, <username> is your real username.
By the way, the recovery files are saved in <homedir>\.comsol\v41\recoveries. You may need to delete the old recovery files to save disk space.
set tmp=D:\Temp
start comsol.exe
If you want, you can create a shortcut for this .cmd file on your desktop. When you run comsol by double clicking on this shortcut or the .cmd file, comsol will create a subfolder like D:\Temp\cs to save big temporary files such as mesh, solution, model files, and D:\Temp\hsperfdata_ to save other information, where is a five digit random number, is your real username.
By the way, the recovery files are saved in \.comsol\v41\recoveries. You may need to delete the old recovery files to save disk space.
2012/02/03 8:58 GMT-5
I know that the tread is quite old, but since I did not find this solution anyplace else, thought I would post it anyways, if someone searches for similar problem.
I am also using COMSOL (v4.2a) on cluster system, that change the home directory after assigning the node, namely from ~./ to ~./pfs. And after that action the directory ~./ is NOT writable, but IS readable (!).
Tried to persuade the COMSOL to use new home directory, with no luck. Found some useful command line options (namely -configuration, -data), but that only got me till reading project file and compiling equations. Failed as soon as wanted to start solver.
Universal solution: make symbolic link from your main home directory, to your working directory, in my case:
ln -s ./pfs/.comsol .comsol
Using such trick I was able to run COMSOL on cluster nodes with no problems (didn't need even -configure and -data options).
If someone in future founds this helpful, I am glad. :)
[QUOTE][..]
[/QUOTE]
2012/05/16 3:51 GMT-4
This is the best solution that worked for me after days of search.
2012/09/21 12:27 GMT-4
Hello James,
Tips on this thread was pretty useful. However, It would be great if you could explain how to add temp switch for comsol execution. I do not know where is command line in the COMSOL installation files.
Thanks a lot.
-COMSOL User
Hello James,
Thanks a lot.
-COMSOL User
Jim Freels
2012/09/23 21:51 GMT-4
I use linux on all my computers, so adding switches to the command line is quite common there.
Windows users can have the same effect by either modifying the icon settings to include switches on the commands embedded within the icon, or by opening a console window and running the commands that are included in the icon.
The COMSOL installation and operations manual explains how to do this for all the operating systems supported.
