Dual energy generation with magnetic seesaw system and gravity
Posted 2016/08/27 1:49 GMT-4 Low-Frequency Electromagnetics, Modeling Tools & Definitions, Parameters, Variables, & Functions 0 Replies
In this technology there will be a balance system and two heavy weight magnets ( HIGH POWER STRENGTH NEODYMIUM MAGNETS 30000 gauss )will be attached with each side of this balance system as per diagram.
As per diagram there will be two moving weights and these moving weights will move on tracks.These tracks will be fixed at the angle of 8 to 10 degree.
Two magnets will be attached on the front side of these moving weights and these magnets will have similar polarity with the magnets of balance system.
These moving weights will be attached with two gear boxes and these gear boxes will be attached with two generators.
HOW THIS TECH WILL WORK?
When one side heavy weight magnet of balance system will be pressed with the help of any kind of external force then this side will come down and repel its side moving weight due to equal polarity of magnets.due to repelling the moving weight will move forward .but when the heavy weight magnet will move upward then this moving weight will move backward due to gravity to get its position back.
in this way this moving weight will work to run a gear box and this gear box will work to start a generator to generate energy.
This balance system will also work to pass through their side copper coil due to linear movement and in this way this technology will generate Dual energy.
WE will take very high strength NEODYMIUM magnets for balance system.
I would like to insist on some following points
(1) The balance system will be attached with 'L' form crank with external PRESSING source.
(2) The moving weights will also be attached with 'L' form crank with gear boxes.
(3) Each side magnet of balance system will work one by one .When one side magnet will come down the another side magnet will move up .These magnets will come down and move up one by one to repel their side moving weight.
(4) We can take as much weight as we can of these magnets of balance system (500 kilogram to 1000 Kilogram or more) to pass through the coils having 100000 turns or more.
(5) External source of pressing this balance system could be anything such as pressing with foot or solar cell. WE WILL NEED ONLY 3 VOLT EXTERNAL ENERGY TO PRESS THIS BALANCE SYSTEM AND GENERATE MORE AND MORE ENERGY.
Please guide me and do some research before any comments.
Hello Vikram Kumar Gupta
