1D integration in 3D domain, need help
Posted 2010/12/21 0:53 JST Version 3.5a 1 Reply
It is a static thermal conduction problem. The geometry is a cubic. The heat source is:
Q=[1-f(T)]*exp(-Int(g(x,y,z,T), 0, z))
T is the temperature.
f(T) is a 2D function of the surface temperature at z=0.
Int(g(T), 0, z)): means integration of g(T) from z=0 to z. g(T) is a function of the temperature in 3D.
So, I need help on two things:
1, f(T) is defined on the surface, but used in the 3D heat source. How to do that?
2, How to do the integration?
For 2, I tried to use an additional function: h(x,y,z,T), and make dh/dz=-g(T)h. For example, if g(T)=1, the function is dh/dz=h, and the boundary condition is h=const.. This method works well in 2D, not in 3D. see post:
www.comsol.eu/community/forums/general/thread/439/
Thanks a lot for your helps (in advance for this problem).
Jiang
Hello Jiangjun Zheng
