Jeff Hiller
        COMSOL Employee
                                9 years ago
                                2016/09/13 21:11 GMT-4
                                                    Have you considered using an app? They allow programming through methods written in JAVA. This can be used to automate repetitive tasks in pre- or post-processing.
                                Jeff Hiller
        COMSOL Employee
                                9 years ago
                                2017/01/11 17:29 GMT-5
                                                    I have added an example that shows how to create a repetitive geometry in the Application Builder in this thread:
www.comsol.com/community/forums/general/thread/133541/
https://www.comsol.com/community/forums/general/thread/133541/
                                Walter Frei
        COMSOL Employee
                                9 years ago
                                2017/01/12 15:30 GMT-5
                            Hi All,
Here is another example:
https://www.comsol.com/blogs/using-the-application-builder-to-create-a-koch-snowflake/
Best Regards,
                                Jeff Hiller
        COMSOL Employee
                                9 years ago
                                2017/02/24 8:43 GMT-5
                        Updated:
                                8 years ago
                                2017/06/05 10:56 GMT-4
                                                    There is now also a recorded webinar that shows how to generate a geometry algorithmically with the Application Builder:
www.comsol.com/events/webinar/Automating-Preprocessing-and-Postprocessing-with-the-Application-Builder-Webinar-23741
Edit: There is a new blog illustrating the use of the App Builder to build a randomized geometry:
www.comsol.com/blogs/how-to-create-a-randomized-geometry-using-model-methods/
https://www.comsol.com/events/webinar/Automating-Preprocessing-and-Postprocessing-with-the-Application-Builder-Webinar-23741
Edit: There is a new blog illustrating the use of the App Builder to build a randomized geometry: https://www.comsol.com/blogs/how-to-create-a-randomized-geometry-using-model-methods/
                                9 years ago
                                2017/04/26 10:17 GMT-4
                                                    Hi Jeff and if we have never used JAVA ,, the app builder could be always used or not?
                                Jeff Hiller
        COMSOL Employee
                                9 years ago
                                2017/04/26 10:51 GMT-4
                                                    I am assuming your question is still with regards to automating geometry creation. Doing so in the Application Builder does require some Java coding.
There are many other things you can do in the Application Builder that do not require any Java coding.
You can also automate creation without using the Application Builder by using MATLAB coding instead (This requires LiveLink for MATLAB).
                                9 years ago
                                2017/04/26 14:30 GMT-4
                                                    The application builder sounds like a great way to achieve this; another easy solution may be using livelink with excel.
Nick
Nick
