mphglobal does not work when model has more than one solution/study?
When I do a Mode Analysis (emw) in COMSOL with matlab I can extract the effective refractive index with
mphglobal(model, 'emw.neff'')
However, if I add another study like thermal stress (ts) to calculate the refractive index profile and then use that to find the modes, I can no longer extract emw.neff.
One would think that something like this should work:
mphglobal(model,'solname','sol2', 'emw.neff')
however mphglobal does not want to take 'solname' as an argument. But, as I was writing this I found that this helps:
[sz,ndofs,list,name,type]=mphgetp(model,'solname','sol2')
and then use "list" to calculate neff with
neff=real(1j*list/(2*pi/lambda0));
Done!
2 Replies Last Post 2012/04/01 15:32 JST
Posted: 1 decade ago 2011/01/21 8:19 JST
Thanks a lot for this very helpful advice!
I am now doing it exactly like this.
I do not know why it is not possible to extract the global variable. And unfortunately the Comsol interface always adds a real around the neff, although it shows the complete complex neff in the selection dropdown menu for the modes.
All this is a bit discouraging and seems arbitrary. But at least with the way via Matlab and mphgetp it works. :-)
Best regards
Arian
Thanks a lot for this very helpful advice! I am now doing it exactly like this. I do not know why it is not possible to extract the global variable. And unfortunately the Comsol interface always adds a real around the neff, although it shows the complete complex neff in the selection dropdown menu for the modes. All this is a bit discouraging and seems arbitrary. But at least with the way via Matlab and mphgetp it works. :-) Best regards Arian
Posted: 1 decade ago 2012/04/01 15:32 JST
Done!
I try
and
and then use "list" to calculate neff with neff=real(1j*list/(2*pi/Lambda)),
but, i wonder why the answer is different by using that two methods.
the Neff is not the same...
do you faced this?
by the way, im using comsol 4.2.
thank
[QUOTE] When I do a Mode Analysis (emw) in COMSOL with matlab I can extract the effective refractive index with mphglobal(model, 'emw.neff'') However, if I add another study like thermal stress (ts) to calculate the refractive index profile and then use that to find the modes, I can no longer extract emw.neff. One would think that something like this should work: mphglobal(model,'solname','sol2', 'emw.neff') however mphglobal does not want to take 'solname' as an argument. But, as I was writing this I found that this helps: [sz,ndofs,list,name,type]=mphgetp(model,'solname','sol2') neff=real(1j*list/(2*pi/lambda0)); Done! [/QUOTE] I try mphglobal(model, 'emw.neff'') and [sz,ndofs,list,name,type]=mphgetp(model,'solname','sol2') and then use "list" to calculate neff with neff=real(1j*list/(2*pi/Lambda)), but, i wonder why the answer is different by using that two methods. the Neff is not the same... do you faced this? by the way, im using comsol 4.2. thank
