Error on cluster calculation based on Window HPC server 2008?
Posted 2010/12/31 17:01 GMT-5 Studies & Solvers Version 4.1 0 Replies
network topology consisted with one head node and one compute node. (The head node compute is also compute node, I think this is a default
setting when I followed the manual for head node deployment of HPCS 2008).
The cluster environment was tested with HPC pack > cluster Manager> Tests and there is no errors. Even when I run clusrun command on cluster
it works find. Thus there is no error on cluster setting.
But when I run cluster calculation with simulation model which worked properly without cluster calculation, I got error.
When I put the following command on the command window on the comsol directory, I can't find the node on compute node and calculation stop without any result.
mpiexec.exe comsolclusterbatch.exe -job b1 -inputfile \\head node computer\test.mph.
node 0 on "head node compute"
node 1 on "head node compute"
I think the command line looks fine but I can't find why the compute node couldn't find on cluster calculation.
Is there any one who have a chance to handle the cluster calculation on HPCS 2008?
Hello rockerbox
