Some questions about the way to express the differential
I know that in comsol ax or d(a, x) represents da/dx, a is a function of x, and x is an space or time independent variable
Are these expressions below correct in comsol? like
1. d(a, b) represents da/db, where a is a function of b, but b is not an space or time independent variable
2. d(da, x) represents d^2a/dx^2, where da = d(a, x), a is a function of x, x is an space or time independent variable
3. d(da, b) represents d^2a/dx^2, where da = d(a, b)a is a function of b, b is not an space or time independent variable
the comsol version is 4.0 or higher
3 Replies Last Post 2011/01/15 6:28 JST
Posted: 1 decade ago 2011/01/14 20:41 JST
First of all this applies only to dependent variables w.r.t. space variables.
So if you have defined a dependent variable "u" of the space x,y,z COMSOl will generate ux, uxx, uy, uyy, uz, uzz, uxy, uxz, uyz, ut, utt (see he doc) all first or second derivative w.r.t. space variable x,y,z respectively or the time "t"
but (pls check I do not know if it i fully true) you need to use the d(,) operator to get a derivative of something else than a depedent variable, and I believe you can only derive w.r.t x,y,z, r,phi or t (to be confirmed). But it's all written in the doc, use an indexer to help you find things in there
Hi First of all this applies only to dependent variables w.r.t. space variables. So if you have defined a dependent variable "u" of the space x,y,z COMSOl will generate ux, uxx, uy, uyy, uz, uzz, uxy, uxz, uyz, ut, utt (see he doc) all first or second derivative w.r.t. space variable x,y,z respectively or the time "t" but (pls check I do not know if it i fully true) you need to use the d(,) operator to get a derivative of something else than a depedent variable, and I believe you can only derive w.r.t x,y,z, r,phi or t (to be confirmed). But it's all written in the doc, use an indexer to help you find things in there -- Good luck Ivar
Posted: 1 decade ago 2011/01/15 1:23 JST
Hi, Ivar, Thanks for your answer.
I find the content in doc about the derivative operator. there is a sentence as " The expressions d(u^2,u) and pd(u^2,u) both equal 2*u ", from this we can see that u is not a independent variable as x, y, z or t. Am I right?
[QUOTE] Hi First of all this applies only to dependent variables w.r.t. space variables. So if you have defined a dependent variable "u" of the space x,y,z COMSOl will generate ux, uxx, uy, uyy, uz, uzz, uxy, uxz, uyz, ut, utt (see he doc) all first or second derivative w.r.t. space variable x,y,z respectively or the time "t" but (pls check I do not know if it i fully true) you need to use the d(,) operator to get a derivative of something else than a depedent variable, and I believe you can only derive w.r.t x,y,z, r,phi or t (to be confirmed). But it's all written in the doc, use an indexer to help you find things in there -- Good luck Ivar [/QUOTE] Hi, Ivar, Thanks for your answer. I find the content in doc about the derivative operator. there is a sentence as " The expressions d(u^2,u) and pd(u^2,u) both equal 2*u ", from this we can see that u is not a independent variable as x, y, z or t. Am I right?
Posted: 1 decade ago 2011/01/15 6:28 JST
take a look at Magnus (he's from COMSOL ;) reply here
www.comsol.eu/community/forums/general/thread/12911/#p34421
Hi take a look at Magnus (he's from COMSOL ;) reply here http://www.comsol.eu/community/forums/general/thread/12911/#p34421 -- Good luck Ivar
