Daniel Smith
COMSOL Employee
9 years ago
2016/11/08 2:30 JST
Hi Louis, when you introduce the glass, you get reflections as well as refraction. This means that secondary rays are released at the material discontinuity boundaries. There is a setting in the Geometrical Optics interface called "Maximum number of secondary rays". The default is 500. This needs to be increased in your model to say, 4000. You also need to solve for a longer time period because the secondary rays may take more time to reach the walls, say range(0,0.003,0.3). If I make these changes in your model then the computed power is 0.99984.
Dan
Dan
9 years ago
2016/11/08 3:53 JST
Thank you very much Dan!
Is there a rule of thumb to estimate how much secondary rays should be released to reach an arbitrary accuracy for the value of power?
I am also not certain of the reason power is lost, even though your fix does work. Why does splitting the intensity into a greater number of secondary rays increase the accuracy?
Louis Haeberle
MSc Student (Physics)
Sherbrooke University
Louis Haeberle
Daniel Smith
COMSOL Employee
9 years ago
2016/11/08 4:00 JST
Hi Louis, there's no perfect rule of thumb to how many secondary rays might be released. Generally speaking, if you release 100 rays and expect them to encounter 5 material discontinuities then that number would need to be 500 for only single reflections. Significantly more may be needed if you need to include multiple reflections. It really depends on exactly what you're interested in.
When a ray hits a material discontinuity, part of the energy is carried by the refracted ray (the primary rays) and part by the reflected (the secondary rays). The amount of energy carried by the reflected and refracted rays comes from the Fresnel equations. If all the secondary rays have been used up, then the reflected rays stop being released into the modeling domain. Their contribution to the overall power balance is hence lost.
Dan
Dan
9 years ago
2016/11/08 4:31 JST
Okay, I understand. So the "Maximum Number of Secondary Rays" setting is the limit for the total number of secondary rays released for all reflections during the whole simulation? For example, if I am modelling an optical resonant cavity where I expect many reflections, I should increase this setting by several orders of magnitude, correct? (Assuming of course that I have enough RAM to solve for all these secondary rays)
Louis Haeberle
Louis Haeberle
Daniel Smith
COMSOL Employee
9 years ago
2016/11/08 5:56 JST
Correct.
Also correct. Once nice feature is the "Threshold intensity" setting in the Material Discontinuity feature. From the User's Guide:
"Enter a Threshold intensity Ith (SI unit: W/m^2). The default is 1·10-3 W/m^2. If the interaction of a ray with a material discontinuity would create a reflected ray of intensity less than the threshold intensity, the release of this reflected ray is suppressed. This prevents an arbitrarily large number of degrees of freedom from being used to model the propagation of rays of exponentially decreasing intensity. When a nonzero threshold intensity is specified, some small decreases in the total energy of the system may be observed if the release of low-intensity secondary rays is suppressed."
Dan
[QUOTE]
[/QUOTE]
Correct.
[QUOTE]
[/QUOTE]
Dan
9 years ago
2016/11/08 7:31 JST
Thank you very much for your help Dan, this information was extremely useful!
Louis Haeberle
Louis Haeberle
9 years ago
2016/11/29 4:22 JST
I am having a similar (opposite actually) problem where I get 1.015 watts out when I put 1 watt in. Do you know anything that could cause this? I was thinking it might be related to a rounding error, but this seems unreasonable.
