Several parameters in fixed solution is not supported
I'm receiving the above error while computing a particle tracing study. I have three studies: 1 stationary stokes flow, 2: parametric sweep (2 variables) stationary electric currents, and 3 time dependent particle tracing with dielectrophoretic and drag forces. The first two studies compute just fine. I'm not quite sure what the error means... It seems like the solver says that it can't compute the particle traces for each case that I'm passing from solver 2 results, which I don't understand, because each individual case works fine.
1 Reply Last Post 2017/02/17 22:19 JST
Hello Benjamin Hawkins
Alex Moreno Bellostes
Posted: 8 years ago 2017/02/17 22:19 JST
Hi i have the same problem, Can you solve the problem??
