Elastoplastic material for vibration isolator.
Posted 2011/01/17 11:48 GMT-5 Acoustics & Vibrations, Geometry, Materials, Parameters, Variables, & Functions, Structural Mechanics Version 3.5a, Version 4.0 2 Replies
I am working in COMSOL 3.5a; I do have access to version 4.0 but I am not yet well-versed in its use.
I am using the Structural Mechanics Module to simulate a structure that is composed entirely of beam elements. I would like to incorporate a non-linear vibration isolator into the structure (not at the base) which has bilinear stiffness, similar to the Elasto-Plastic material model with kinematic hardening. I initially intended to include a beam element, constrained for lateral motion only, with elasto-plastic material, to achieve the desired isolator stiffness, but it appears I can only use a linear elastic material for my beam element.
Can anyone suggest a method of modelling such an isolator simply? I had the idea of "exploding" the model and creating a 2-D body which could approximate the desired stiffness properties of the isolator, but ideally I would like to use a beam element for simplicity - the physical details of the isolator itself are not of concern in this simulation, only the characteristic stiffnesses and yield displacement.
Thanks in advance.
Chad
Hello Chad Van der Woude
