                                2011/01/17 15:13 GMT-5
                                                    Hello Juergen,
I've successfully  installed the update on a 32-windows machine... though I see you have 64. I may need to do so on 64 too. Please update us on this issue
Good luck!
Stephan
                            Hello Juergen,
Good luck!
Stephan
                                2011/01/17 15:43 GMT-5
I installed the 4.1.0.112 patch on both 32 bit and 64 bits Win-7 without any trouble, several months ago. Has anyting changed with the OS since ? as now everything gets so interconnected ?
                                2011/01/18 7:38 GMT-5
                                                    I have emailed the comsol support team. As soon as I get an answer and the patching works, I will post the right steps here.
Thanks all,
Juergen
Thanks all,
Juergen
                                2011/01/19 16:57 GMT-5
                                                    I just installed the patch on my Win-7 32 bit machine.  However I received the same "unable to create .." error message with my Win XP 64 bit machine.
                                2011/01/20 8:39 GMT-5
                                                    Hi all,
the comsol support wrote a very helpful email.
You need to stop all running comsol processes.
Although the Comsol program window was closed, the windows task manager still showed a running "comsol zombie" process.
When I stopped that one, I could install the patch successfully without that strange error message.
Hope that helps,
Juergen
                            Hi all,
Hope that helps,
Juergen
                                2011/02/11 19:46 GMT-5
                                                    Jurgen,
  Thanks for the tip.  I rebooted, then ran the installer again, and everything was able to unzip and install.  I didn't have to kill any processes.
  - Bob
                            Jurgen,
  - Bob
