long simulation batch (or parameter sweep)
Posted 2016/11/19 9:48 JST 0 Replies
I've read about doing long simulations in steps to avoid large files. This is perfect for my situation as I'm only interested in the variation over one day, but I need to let the system equilibrate over many days. I plan to delete the files for days before the system has equilibrated.
Is there a way to combine this approach with a batch or parameter sweep? Namely I don't want to go in and change the initial value to "current solution" 50 times if there's a way to do it just once.
I need to run the full simulation for each parameter combination which should be possible with batch sweep, but I haven't found a way to also break each simulation in the batch sweep into steps to avoid large files (one full simulation is ~30GB when not broken into steps).
Hello Catherine Elder
