gyroscope model
what is the meaning of expression acos(mbd.hgj3.e1z)?
1 Reply Last Post 2016/12/02 6:31 JST
Posted: 9 years ago 2016/12/02 6:31 JST
To find the definition of any variable:
1. Switch on display of tags in the model tree.
You will then see that this variable comes from
mbd: Multibody Dynamics
hgj3: Inner Gimbal-Spinning Disc (which is HinGe Joint 3)
2. Turn on Equation View and look at the variables in the Inner Gimbal-Spinning Disc node. See attached screenshot, which shows that it is 'Joint axis, z component'.
Henrik
Hi, To find the definition of any variable: 1. Switch on display of tags in the model tree. You will then see that this variable comes from mbd: Multibody Dynamics hgj3: Inner Gimbal-Spinning Disc (which is HinGe Joint 3) 2. Turn on Equation View and look at the variables in the Inner Gimbal-Spinning Disc node. See attached screenshot, which shows that it is 'Joint axis, z component'. Regards, Henrik
