Beam - Rigid Body
Hi everyone. Is it possible to get a rigid beam?
Thank you for your help.
P.S. I'd like an infinite Young's modulus, not a finite Young's modulus.
4 Replies Last Post 2016/12/22 6:15 JST
Posted: 9 years ago 2016/12/21 16:31 JST
I do not believe that was possible back in old 3.5 days ;)
Today with the newer versions there are the "Rigid Body" domains and the full RBD module to handle this.
Hi I do not believe that was possible back in old 3.5 days ;) Today with the newer versions there are the "Rigid Body" domains and the full RBD module to handle this. -- Good luck Ivar
Posted: 9 years ago 2016/12/21 17:02 JST
Hi Ivar,
in my university there is only the 3.5a version of Comsol, so I can't use next versions.
GA.
Hi Ivar, in my university there is only the 3.5a version of Comsol, so I can't use next versions. Regards, GA.
Posted: 9 years ago 2016/12/22 4:50 JST
Hello
Well back in 3.5 time, I used the trick you just said: turned up the Young modulus, to make my "rigid" parts real stiff.
But do not overdo it, 1000 to 10'000 times is already quite a lot, as else you might get numerical scaling issues. Note that eigenfrequencies scale as sqrt(E/rho) so these increase less than the Young modulus.
Hello Well back in 3.5 time, I used the trick you just said: turned up the Young modulus, to make my "rigid" parts real stiff. But do not overdo it, 1000 to 10'000 times is already quite a lot, as else you might get numerical scaling issues. Note that eigenfrequencies scale as sqrt(E/rho) so these increase less than the Young modulus. -- Good luck Ivar
Posted: 9 years ago 2016/12/22 6:15 JST
Hi Ivar,
I'd like to avoid the possibility of numerical issues. Is there another way to do it? The bigger Young's modulus, the bigger the possibility of numerical issues.
Thank you very much,
GA.
Hi Ivar, I'd like to avoid the possibility of numerical issues. Is there another way to do it? The bigger Young's modulus, the bigger the possibility of numerical issues. Thank you very much, GA.
